NX spray bar in Holley tbi adaptor
Old May 3, 2003 | 07:22 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I got some extra funds to play around with so I think Im gonna spray the 305 at the end of may assuming dad doesnt veto it. I dont have room to run a carb -> tbi adaptor and a nitrous plate, my air cleaner rubs the hood as it is right now, so I guess I'll try to get a spray bar machined into the holley adaptor.
Where should I get it put? I figured it would either go up directly under where the tbi sits more twards the front of the manifold so I guess it would mix with the air/fuel more evenly? Or directly in the middle of the adaptor in the middle of the manifold?
Picture of how the adaptor sits
Thanks guys.
Old May 5, 2003 | 02:48 AM
25THRSS's Avatar
You are gonna need to put it directly across the holes. Seems like a lot of work to me. Why don't you just save up a little more and get a cowl hood?
Old May 5, 2003 | 05:32 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
I figure the machine work cant be more than $100, if it is I'll forget about the idea all together I reckon. Already have the Holley adaptor and if not I can get another one from PAW for $13 or something. A cowl would be nice but that's about $500 on top of whatever nitrous is gonna cost upfront and I cant spring that.
Old May 7, 2003 | 08:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
chuck let me know how that works out, i had the same idea for mine, but i need to wait for some tranny work before i feel ok with spraying.... the way things are going i would spray it the first time, and spit gears through the case.
Old May 7, 2003 | 09:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have seen people cut up a nitrous plate and notch the top of an intake to put the spray bars in the intake by epoxy/jb welding them permanently in place it worked out real nice too. The divider for the dual plane must be cut down too (best performed with an end mill at a machine shop) the spray bars replace the removed portion of the divider.
Attached Thumbnails NX spray bar in Holley tbi adaptor-resessed-spray-bar.jpg
Old May 7, 2003 | 10:10 AM
Dewey316's Avatar
Car: 1990 Camaro RS
that might work great for me, i am running a single plane.
Old May 7, 2003 | 01:31 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
What about using one of those low clearance air filters... Might get you the extra inch or two you need..
Old May 7, 2003 | 05:09 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
What about the NOS topshot ?
Old May 8, 2003 | 05:54 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
fogger
nos has a tbi plate 13429NOS
Old May 8, 2003 | 06:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i know nos has a plate for TBI, the problem is i dont' have room for an extra 1/2 plate.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
