Anyone with a TPIS mini ram on a supercharged engine
Old May 9, 2003 | 02:30 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
Just wondering what kind of performance and gains were experienced with using the TPIS mini ram on a blown engine.
Please post.
Old May 9, 2003 | 04:05 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
I forget which issue of CHP it was, but they had a 302 chevy running 600 hp with a vortech supercharger running 17 psi of boost and a tpis miniram. They said they knocked down 24 mpg with the motor if I remember right.
Old May 9, 2003 | 04:40 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Crips... thats an old one. 1998 IIRC, Killer built 302... it was in Jeff Smith's chevelle.. he later ran it at one of the Silver Streak runs..
BW
Old May 9, 2003 | 05:17 PM
Guido's Avatar
Car: 2000 Trans Am
I have that book at home somewhere. I had a miniram and s-trim vortech for a while. it had a great low end punch. I had a smaller stall converter then too.
It works good but it being a front fed manifold, it suffers from some inefficiency from port to port. If you HAVE a Miniram, id keep it and use it. If you dont, I wouldnt buy it. There are plenty of other well designed intakes that would work fine. I use a carb style manifold with a 90 degree elbow and a single mustang throttle body.
Good luck
Old May 9, 2003 | 09:07 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
I have a miniram with a r-trim vortech, runs good, need to get some more dfi tunning figured out. I know of 3 other people that run a mini ram with a vortech, all cars are running single digits, but I have heard some issues from them as to problems with the inefficiency from port to port as Guido stated.
Old May 10, 2003 | 12:25 AM
BlownBird's Avatar
T.Hess is running a Miniram on his F1R setup with not a single problem... 9.20's so far!
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
