just the procharger on the front of the motor?
Car: 1992 B4C 1LE
Im thinking of building a rigid spacer to replace the serpentine bracket on the drivers side to mount my blower bracket to and mount just an alternator on the pass side. The alternator would be kind of low mounted as possible. My intention is to do away with all of the items on the front of the motor except the blower and alternator. I will run a electric waterpump, run no PS pump, air pump, ac compressor etc. anyone else done this? Thoughts on this?
No never seen it done. but I think it would work.
they do make a electric water pump with a free spining pulley on it so you could get a short belt and leave the alt where it is.
you'd have to make a tensioner for it some where.
Car: 1992 B4C 1LE
Instead of a free pulley on the WP I figured a lowmount alt bracket an a very short belt just between the alt and crank no idler with the new alt bracket I can adjust the alt to tighten/loosen the belt.
Car: Damn
Engine: This
Transmission: New Stuff
I don't see any reason why it wouldn't work. So a small (v belt?) for the alt and then the fat blower belt right? I can see it working fine.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
