Turbo Prices??!?!?!?!?
Old May 30, 2003 | 06:39 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Okay I know you guys are **** about turbo questions but I have searched and read, all they give is info, I want to know apox. how much $$$ for a average turbo. Thank you.
Old May 30, 2003 | 07:50 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
prices for the turbo units themselves can be found not only at precision (for race turbos) but also on e-bay (all kinds of turbos)
Old May 31, 2003 | 10:09 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
depends of what you want... t-25s are like $50 - $70. but they suck t3s are bit more. it all depends on where it comes from.
Old May 31, 2003 | 02:43 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
THATS IT!!! wow. what else do I need to get it working
Old May 31, 2003 | 06:53 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
t-25s are too small for v8s. they are almost too small for 4 bangers (hence the cheap price). shrug your best bet is to go jy hunting.
Old May 31, 2003 | 07:14 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
So what else do I need besides a Turbo?
Old May 31, 2003 | 07:48 PM
True Power's Avatar
Just about everything. Headers, custom intake piping, probably a built bottom end, modified carb or custom programmed computer, a tranny that can handle more power, same thing for a rear end
Old May 31, 2003 | 07:52 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Can my Rear end handle like 400 Hp (mines stock)
Old May 31, 2003 | 08:41 PM
True Power's Avatar
if you can get traction (ie running slicks), then i believe the answer would be a big negative
Old Jun 1, 2003 | 08:35 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
According to sphoon 400hp + slicks = BOOM. Turbos are progressive (no power off idle) so they aren't as hard on the drive train as a N/A or roots blown motor.
Old Jun 2, 2003 | 10:02 PM
Momar's Avatar
Yeah, but if you have an aftermarket stall or manual you kind of cancel that out because you can jump right into the powerband.
Ben
Old Jun 4, 2003 | 02:10 AM
onebadwagon's Avatar
actually, if its a turbo car with no 2step you probably wont break the rear,
my roommate has an incon mustang, and he cant even get out of vacuum coming out of the hole, without a 2 step.
adam
Old Jun 4, 2003 | 07:20 AM
Momar's Avatar
Two step? Are you referring to a sequential setup? Anyway, I have a thunderbird turbo coupe and it will put out a ton of boost off the line. I know thats not exactly the same thing since it is a stock setup, but on a v8, I would bet that you could still end up making boost off the line with a decent sized turbo because of the amount of exhaust a v8 puts out compared to a 4 cyl. Either way, you have to be careful with a 7.5" 10 bolt(especially in stock form) with slicks on it. They just dont have a lot of strength to them.
Ben
Old Jun 4, 2003 | 01:39 PM
i have alot of friends with ls1's who have made tons of nitrous passes on slicks, hitting 1.5 60'.
im telling you bro, its hard to get boost off of the line without a 2 step rev limiter.
adam
Old Jun 4, 2003 | 01:51 PM
Momar's Avatar
Sorry for my ignorance, but could you explain a two step rev limiter and how it helps you get boost off the line.
Also, what do nitrous runs have to do with turbos? Also are they all running stock 10 bolts with those 1.5 60 ft's? If they are they are brave. Also, the LS1's have a slightly larger ring gear than he does and also they have 28 instead of 26 spline axles. I would bet that if their rears are lasting through those kinds of 60 fts though that they are at least modified some(support cover, aftermarket gears, axles, ect...)
Ben
New2Chevy
Sep 28, 2015 12:35 AM
pimprs
Sep 10, 2015 03:34 PM
Stryker412
Sep 7, 2015 09:11 AM
84 TA NV
Sep 6, 2015 08:02 PM
