Garrett T25
Old Jun 1, 2003 | 08:44 PM
Acidtalons's Avatar
Garrett T25
Would a Garrett T25 be a big enough turbo for 1.8 Liter engine thats looking to run 6 - 10 lbs of boost?
Old Jun 2, 2003 | 01:38 AM
Acidtalons's Avatar
anyone?
Old Jun 2, 2003 | 02:27 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i mite give you 6lbs...one off of a dodge 2.2L minevan should work to...
Old Jun 4, 2003 | 12:37 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I just sold the T-25 from my Talon.
They are good for 15-18 PSI on a stock 2.0L engine before becoming inefficient. I must say, by redline it wasn't able to supply enough air and it would drop to about 13-14 PSI.
So. On a 1.8L engine only running 6-10 PSI, it would be perfect. They spool VERY quickly and can be found for very little money.
Old Jun 4, 2003 | 02:11 PM
83 Crossfire TA's Avatar
I’ve said it before here and I’ll say it again, it takes a bigger compressor to blow the same amount of air at a lower pressure, so just because a turbo will work at 20psi on one combination it doesn’t mean that it can still pump that same amount of air at 10psi.
jnjspdshop
Oct 19, 2004 11:34 PM
firebird89355
Oct 17, 2004 08:51 PM
Com_VC
May 5, 2004 04:24 AM
Lee7
Aug 5, 2003 09:13 PM
