people with blowers look inside
Old May 26, 2003 | 07:30 PM
1984 trans/am's Avatar
i have a few questions about the holley 144 and weiand 172 superchargers.
how much power did you fell? what boost is it set at?
how hard was it to install? do you have any problems with it?
i am thinking about purchasing one tomarrow morning, and i would like to also know what heads from afr should i be using or should i just stick with my ported L98 heads. i have a 4" cowl, will there be a clearance issue. i have a 383 stroker in it right now.
Kingtal0n, your name is jordan right? a few months back a kid named jerry saw you at the chevron on eurika and old cutler road when you had the power charger on it, i am him, i was on the atc getting gas and we stopped and talked. remember me?
Old May 26, 2003 | 07:55 PM
vwdave's Avatar
This motherf*cker right here is someone I consider my best friend. But it still makes me laugh when I ask this.
Jerry, how big is the explosion be when you strap that thing to your engine? I am guessing 2 megatons.
Old May 28, 2003 | 02:10 AM
83 Crossfire TA's Avatar
Re: people with blowers look inside
Ported L98... yuck... lots of cheaper heads that you could have used that would have worked better...
Oh well, I guess boost can overcome many atrocities
Old May 28, 2003 | 02:35 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i don't think the 177 will fit under that hood i'd use afr 210s. whats your cr? you should be able to make an ez 500hp
Old May 28, 2003 | 11:08 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
is there an intake for a 177 or 142 that will fit the ports on a set of 210's?
Old May 28, 2003 | 02:10 PM
they came with the enigne. it is running 9.5 to 1 compression. clearance is not a problem, i have a 4" cowl hood on the car. whats teh best heads should i use with the blower/
Old May 28, 2003 | 02:38 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
brake out the die grineder
Old May 28, 2003 | 06:11 PM
vwdave's Avatar
All you need to work on cars is a Plasma Cutter, welder, and a die grinder.
With those, anything will fit anywhere.
Old May 31, 2003 | 05:57 PM
BigL350's Avatar
Do I detect an impending ricecop takeover?
Old Jun 2, 2003 | 05:35 PM
Damon's Avatar
You'll have a touh time fitting jsut a little 142 under a 4" hood. A 177- no way. You'll need one of those massive "outaw" style cowl hoods to fit it. Don't forget you still have to fit the carb and a reasonably sized air cleaner under that sucker.
Do a search of old posts (archives) under my screen name. I wrote a phone book about installing one of these units. If you can't find it- email me and I'll send it to you.
Power increase: on the order of "Holy Cow!" Not quite as good as nitrous, but then I was only pushing 4 PSI at the time.
I've learned a LOT about these nifty little blowers having had one on 2 separate motors now, so I can give even more tips than what's in my article, if you would like.
Old Jun 3, 2003 | 12:11 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Damon, your setup is in a Malibu right?, if so what hood do you use or is it sticking through?
Old Jun 4, 2003 | 06:23 PM
Damon's Avatar
Yeah, a 78 Malibu. 2-1/2" Harwood cowl hood. Qjet carb (is about 1/4" shorter than a Holley) and a 2-1/2"x14" open element filter in a housing with a 1-1/2" drop base. Air cleaner base is shaved and trimmed within an inch of it's life for every possible millimeter of hood clearance. It just couldn't possibly be a tighter fit no matter what you do to it.
My bu has proably at least an inch more hood clearnace to start with than a 3rd gen F-body, too.
Old Jun 4, 2003 | 06:26 PM
vwdave's Avatar
Hey BigL, problem with your theory. I dont think even BB's postwhoring would make much of a dent.
Ricecop....1200 members.
Thirdgen.org 22k members.
We dont have anything on them.
Old Jun 4, 2003 | 06:47 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I have not idea how I managed to get both M90's under a stock hood...just barley fit...
stay tuned... weather permitting, and trailer permitting, the Malibu makes its first run at Kilkare tomorrow.
Don't expect killer times, since I am running radial ta's but the top end charge should be fun...
cheers, Bob W
codeysabatini
Nov 10, 2015 04:07 PM
camaroracer21
Oct 6, 2015 03:23 PM
WejaZ28
Oct 3, 2015 07:38 PM
usafirebird
Oct 1, 2015 01:57 PM
usafirebird
Exterior Parts for Sale
Sep 21, 2015 01:23 PM
