Anyone using CompCam 08-502-8 in there T.P.I 350?
Old Jun 5, 2003 | 10:55 AM
CustomCarShop's Avatar
Is anyone using a Comp Cam, Part # 08-502-8. In there T.P.I 5.7L?
I E-Mailed Comp Cams, and they suggested me this cam, I am just wondering if anyone has this cam, and how they like it?
Old Jun 6, 2003 | 07:54 AM
Damon's Avatar
Xtreme Energy Hyd. Roller 269. 218/224* duration, roughly .500" lift, 112* Lobe Separation Angle.
I haven't used it but it should work well on a moderately modified TPI.
Make sure your heads can handle that much lift without the retainers hitting the valve guides (most stock heads poop out around .470-.480 or so) and make sure you use the correct valve springs AND then they are checked for proper installed height to give you the correct seat pressure!
Old Jun 6, 2003 | 10:30 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah at worst not putting in new correct valve springs will make your car act like it is hitting a rev limiter at best it will just be robbing you of power you could have used but never know is missing.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
