Junkyard Intercoolers
Car: 1989 Iroc Z L98
Are used intercoolers a good idea? Will a junkyard intercooler suffice for a supercharged application under 10 psi? If so, what are some good donor cars/trucks to look for?
Car: 1992 B4C 1LE
some huge diesel intercoolers suffer close to 30 psi in stock applications (way more than 20 atleast)
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
If you can weld aluminum or know someone who can, it's probably not worth it. DSMs make ~200 hp stock @ ~8-12 psi (don't know). So 2 of them should be decent for 400-500 hp. 3 for 600 hp ect. Maybe stock supra or GN intercoolers. Just think there's probably a reason why those guys swap to aftermarket ICs and make more power. Check E-bay for cheap aftermarket ICs.
Lots of guys using Ford Power Stroke Intercoolers on their GNs and going deep into the 10's with it and they are fairly cheep. I think you can get them for under $200.00. Getting into the 3rd gen I am not sure how hard it is. There are two types of Power Stroke IC's, you don't want the one with the plastic end tanks. If you are interested and see the Pics go to Turbobuick.com and do a search, it will lead you to member’s sites with all the descriptions.
Good luck
Prasad
Good luck
Prasad
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Back from the land of old posts.
I've been looking at a LOT of intercoolers on ebay. I've seen ford thunderbird intercoolers go for $32, a volvo one go for $26..
Anyone compile a list of OEM intercoolers and how well they work, flow?
-- Joe
-- Joe
When I did my junkyard IC search for a different car I scored off a Volvo 740 turbo. The Volvo IC was a perfect match for the single Garrett T3 turbo I was running (flowing like 230 cfm or something?), and would work in a front mount design. If you're running more than 1 turbo (aka twin) or a turbo bigger than any OEM setup, then you might have to use multiple junkyard IC's. Any older OEM turbo car that came with a IC would be a good donor. Ford Turbocoupes, Mustang SVO, Volvo 740 turbo, older Audi's. Even stock IC's from newer turbo cars could be used (Neon SRT-4, Evo 8, WRX STi), but these would more likely be in the sunday paper listings than the junkyard ...
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Nah. I'm a bad plumber..
I was thinking maybe a BMW intercooler.. they have 3" in-out and they're kinda small. Put that right under the car.
But then I'm thinking, ok so I'll get a cooler charge, but I'll loose like 3psi of boost.. ug..
-- Joe
-- Joe
Actually, there was this guy who was real good with welding and I saw a pic of an intercooler he made using 3 of those Volvo 740 IC's (all welded together). I dunno exactly how he did it. It was really ghetto looking but it did work. This is always a possibility if you happen to be good at welding.
Terrell351
Jun 13, 2021 01:13 PM
Damon
Sep 26, 2015 04:29 PM
