is there a big advantage to a mod. carb intake on efi
Old Jul 2, 2003 | 08:56 PM
00turboblazer's Avatar
juat a curious question before i mod. an LT1 itake i have layin around. I was just wondering because it would be SO easy to put some injector bungs and a large LS1 style throttle body on and go for it, I may just try it for the hell of it?!?!
BTW its going on a sb forced induction 355
Old Jul 4, 2003 | 12:10 PM
c'mon guys ANY help is appreciated!!!!
Old Jul 5, 2003 | 01:49 AM
89ProchargedROC's Avatar
its not as easy as you think.....
you need to drill the holes in the exact center of each port and use a bridgeport mill. Then you have to make sure to drill the holes in the same exact spot as well and then after you get done drilling the holes in the fuel rails you have to use an end mill to square it so the o-rings can seat
plus welding the bungs in the intake is no easy task (to do right anyway)
here are some pics of my conversion:
http://home.earthlink.net/~tt3rdgen/intake.html
Old Jul 5, 2003 | 11:16 AM
wow that looks really good, i have access to a bridgemill and other tools to do teh job right BUT like I said if i go from a TPi unit now to that what should i expect to see as far as gains and losses or should i say pros and cons.
Old Jul 5, 2003 | 01:06 PM
turbotater's Avatar
under pressure ( turbo maybe ) i would
believe the carb style intake might have
an advantage .. N/A the longer runners
of the tpi would be better in a heavy old blazer
to get it to launch decent
the lt1 needs to be given to me to free up
your floor space ..
mike
Old Jul 5, 2003 | 06:30 PM
well mike ill go mesure the intake and see if you got room on your floor for it we may just do a lil tradin
Old Jul 6, 2003 | 02:35 AM
your floor space ..
mike
true, but in reality the runner length on my victor junior is longer than the runners on the LT1 intake
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
