NOS problem?
Old Jul 9, 2003 | 12:18 AM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
NOS problem?
ok I knew my bottle was pretty much empty but had compressed air but I wanted to try it anyway. So I flipped the switch and the car bogged down bad and woudl accelerate well was it cause it was spraying air and no Nitrous? car ran fine ones I turned it off.
IDEAS?
Old Jul 9, 2003 | 11:16 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
If you are running a wet kit the problem is you are spraying no nitrous and stright fuel. You are infact flooding the car with gas. The car is unable to burn all the exta fuel.
Old Jul 9, 2003 | 11:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: NOS problem?
IDEAS?
umm so you sprayed compressed air into the car??
heh, the reason NitrousOXIDE works is it has a higher then normal Oxygen content.... spraying compressed air into that would do nothing. the only way to see any benifit from regular compressed air would be to have a LARGE valve and a LARGE volume of highly compressed air, and when you opened the valve and closed off the intake it would allow for some boost.. but it would be short lived as the engine would suck it up fast... and its totally impractical.
btw, dont spray straight oxygen into your motor either. it will melt it.
Old Jul 9, 2003 | 12:46 PM
I RoC A Z's Avatar
yeah it smelled rich after trying to spary, I figured it was caue there was no Nitrous left
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
IROCZ1989
Sep 4, 2015 11:54 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
