Electric Superchargers, do they work
Old Jul 27, 2003 | 05:13 PM
bonz's Avatar
Car: 89 GTA
I have seen these electric superchargers on ebay. They look like they are basicaly a heater blower fan in a fansy housing. I was wondering if they actaully work or are just a joke. If anyone knows anything about this let me know. THANKS
Old Jul 27, 2003 | 05:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're worse than a joke.
Old Jul 27, 2003 | 06:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not only do they not help, but they can distroy your engine.
1. they have a propeller.... they cannot even create boost.
2. they dont flow enough air. so what happens is the air is sucked thru it, spinning the blades faster then what they are ment to spin... eventually they break...... but since its installed after the air filter, the plastic pieces go into the engine... distroying it.
3. even if you had the most baddass leafblower attached to your intake, it wouldnt flow enough air.
Old Jul 27, 2003 | 11:47 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
they move just enough air to cause idle problems, and as told your engine will merely try to suck that little piece of junk inside out and when it achieves that the guts will not mix well with the guts of your motor they will likely be in disagreement. BTW, please do a quick search using "electric supercharger", I wouldnt want to see you get flamed here.
Old Jul 28, 2003 | 09:32 PM
bonz's Avatar
Car: 89 GTA
Thanks for the help. I didn't figure they would do any good.
Old Jul 29, 2003 | 10:41 PM
onebadwagon's Avatar
mine works great
adam
Old Jul 29, 2003 | 11:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
do you have any idea how many jokes around the internet revolve around that "toro-toro" setup in the pic? Hell there are even urban car legends among import jackasses about it.
Old Jul 31, 2003 | 12:02 AM
dont be scared tom. i've started my own subculture
adam
MustangBeater20
Oct 29, 2022 09:20 PM
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
lakeffect2
Aug 23, 2015 08:44 AM
