big diff in carb or efi turbo setups?
Old Jul 31, 2003 | 12:04 PM
NOSFEDGTA's Avatar
I was wondering it it is any easier or harder with either setup? i want to do a turbo motor and currently run a carb in the car. I have run efi forever and jsut swithced to a carb a little while back. The reason was for money and other things I had going on. What I want to know is should I just go ahead with what I have or will a turbo carb motor be a nightmare? anyhelp would be great
Drew
Old Jul 31, 2003 | 04:49 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: big diff in carb or efi turbo setups?
Drew
If you pick up the newest super chevy (i think it was super chevy), they had a Vortech supercharger install on a carbed 1st gen Camaro. It seemed like the hardest portion of the install for them was getting the boost referenced fuel pressure regulator dialed in. The results werent too impressive either but they said they didnt get a chance to play with timing either.
Old Aug 1, 2003 | 05:46 AM
BOTLFED's Avatar
Both have their pro's and cons.. This is a excert from Mike Sitar.. (www.toohighpsi.com)
TT Capri
351W
8.0 compression ratio
Out of the box TFTW heads
2 - .63A/R 60 trim T3s
charge cooler
flat hydraulic cam - 216/228 @ .050"
Vic Jr intake (I think)
1 5/8 headers
600 DP
2.73 gears with 26x11.5 tires
TT Mustang
351W
Lightly ported GT-40 heads
charge cooler
roller hydraulic cam - 226/226 @ .050"
351 EFI truck lower intake - custom upper
77 lb/hr injectors
1 5/8 headers
3.08 gears with 28x10.5" tires
Cars weigh the same. Tough to beat the EFI car off the
line, boost response is much faster (almost violent)
due to the correct A/F at all points and the ability
to have complete timing control. After the 60' the
cars are dead even. Made for some great heads-up
racing yesterday!!
// End excert
Turbo carb cars (blowthru) can be a pain to get tuned correctly, but so can EFI I guess.. I'm having a heluva time trying to get my blowthru setup tuned, but I'm thinking that it's my carb that's the issue right now..
Cheers,
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beachrodder
Aug 25, 2015 08:05 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
