Can anyone identify these injectors?
Old Aug 17, 2003 | 10:32 AM
1 GTA's Avatar
Car: 1988 Trans Am GTA
Engine: Twin Turbo-Charged, Intercooled SBC
Transmission: Reverse Manual TH400
Axle/Gears: Aftermarket 9-Inch, 3.50 Gearset
Does anyone have any info regarding the injectors shown below? I'm told they are Bosch style, low impedance, 160 lb/hr injectors, but the Ford part number given (XL3Z-9F593-CA) doesn't match the one given by FordMotorsport/SVO (DFM9F593A150). I was told the injector was used by Ford in their natural gas engine line, and when used with gasoline, the injector flows 160-165 lb/hr. I was informed that this injector is very popular among the Pro 5.0 car making BIG (1500+) HP. Can anyone shed any light on this myth and injectors????
Old Aug 17, 2003 | 10:42 AM
91blackgta's Avatar
Re: Can anyone identify these injectors?
160 lb/hr?
Old Aug 17, 2003 | 11:22 AM
1 GTA's Avatar
Fuel injector flow rate is measured in pounds of fuel per hour (lb/hr)
Old Aug 17, 2003 | 11:54 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I think he meant "160 lb/hr?" as in like "holy ****"...
Old Aug 17, 2003 | 12:36 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
This site may be usefull http://www.geocities.com/ttskipp/injector.html
Old Aug 17, 2003 | 12:55 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Yenko, thanks for that info, it will come in handy when I need my larger injectors.
Old Aug 17, 2003 | 01:04 PM
1 GTA's Avatar
Yes, thank you Yenko for that link. I'll ask again if there are any numbers stamped into the injector which might help in determining it's size.
Old Aug 18, 2003 | 06:46 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have seen alot of 2.9, 3.0, etc fords with a grey topped injector its smallish. Not to say thats what those are for sure, without the number who knows I found THESE
Old Aug 18, 2003 | 11:23 PM
83 Crossfire TA's Avatar
All of the ford/bosch style injectors that I know of with a light gray top fit into 2 categories:
- there’s a bunch of 14-18lb/hr injectors used in a bunch of the smaller ford MPFI engines
- 52lb/hr injectors used in the 83-84 5.0+auto TBI cars.
Have you tried measuring the resistance across the terminals? That would narrow things down a bit. Also any bosch injector should have a bosch # on them that starts with a 280…
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
