Cylinder head suggestion?
Old Aug 20, 2003 | 11:41 PM
jnjspdshop's Avatar
I was wondering what everyone on here would go with and for what reason. I plan on building a bullet proof 5.7" rod 383 engine with around 7.8-8.0:1 I am gonna purchase an ATI F1 blower for this combo and I need to decide on a cylinder head.
So far I am looking at
100% CNC AFR 195cc
100% CNC AFR 210cc
Trickflow R big port
Canfield 220cc
Dart Pro I's in 200cc
Any ideas or suggestions. I am leaning toward the AFR 210cc because of the strong exhaust side
Old Aug 20, 2003 | 11:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
AFR 210's
Old Aug 21, 2003 | 07:35 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
AFR 210's for sure. Out of curiosity, why dont you want to run a 6.0" rod?
Old Aug 21, 2003 | 09:55 PM
jnjspdshop's Avatar
Cause I was confused. I do want a 6.0" rod, I thought it was the other way around and the 5.7" rod put less strain on the side walls of the cylinders
Old Aug 23, 2003 | 08:00 AM
iroczman380's Avatar
Any of those heads are good, but what rpm range do you want to run in??? with a supercharger i would keep it down at lower rpms if its a street/strip application. Check out the vortecs and the fastburns they are bad *** heads and outflow afr's on the intake side, with little or no porting.!!
Old Aug 23, 2003 | 08:04 AM
jnjspdshop's Avatar
Wasn't aware of the flow numbers of the vortecs or fastburns. Correct me if I am wrong but isn't the most important thing for a blower car is to have a head that flows excellent on the exhaust side?
Old Aug 23, 2003 | 02:38 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Don't waste your time. Go w/ AFR 210's.
Old Aug 23, 2003 | 04:48 PM
Vortecs are good cylinder heads, but when you get into larger displacement motors like a 383/400, you will want larger intake runners on the cylinder heads to feed the motor, and frankly a 170cc intake runner will not feed a modified 383/400 naturally aspirated to its full potential, let alone a supercharged 383/400. He needs a cylinder head with larger ports like an AFR 210 to help feed a boosted 383/400.
Old Aug 24, 2003 | 08:18 PM
KYL98's Avatar
Car: 1991 Z28
I would go with the AFR210's......Vortecs and Fastburns are good.....but they are not Aluminum(except Fastburn alum)....Aluminum heads allow for more timing without detonation....and have better heat dissapating properties....all good things for a blower...especially if its NOT intercooled.
Old Aug 24, 2003 | 09:35 PM
Fast burns are aluminum.
Old Aug 24, 2003 | 10:31 PM
KYL98's Avatar
Car: 1991 Z28
there were some fastburns that WERE cast iron.....
Old Aug 25, 2003 | 12:37 AM
Even the prototype fast burns are Aluminum. You are probably thinking of the cast iron Vortec heads, which have a "fast burn" combustion chamber.
Old Aug 25, 2003 | 10:27 AM
KYL98's Avatar
Car: 1991 Z28
No...they dont make them anymore....but there were some Fastburns that were cast iron. Ive got an old GMPP catalog somewhere....If I can find it Ill scan the page or get the part number. I believe that they had a smaller intake port(180?) instead of the 210cc like the alum heads. I know the Vortec heads have the same shape...but they are 170cc. I will try to find that catalog
Old Aug 25, 2003 | 10:48 AM
Guido's Avatar
Car: 2000 Trans Am
AFR210
Old Aug 25, 2003 | 01:14 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
i heard iron heads were better for turbo boost
Old Aug 25, 2003 | 02:31 PM
Supposively the heat dissipation properties of aluminum help to prevent detonation. However, I don't think that the difference that aluminum heads make is as extreme as many would lead you to think. I know plenty of people running 11:1 on pump gas and cast iron heads, its all about the camshaft selection .
Old Aug 25, 2003 | 02:45 PM
KYL98's Avatar
Car: 1991 Z28
Aluminum heads are MUCH better for blown applications in that they dissipate heat better....which allows more boost/timing without detonation because of cylinder temperatures being less. Cast iron heads are fine for naturally aspirated motors.....I just wouldnt run them on a supercharged engine...cant speak for turbo's...not too familiar with them. And as far as running 11:1...why would you want to on a blown car?? The cam youd have to run with that wouldnt work very good in forced induction...because it would bleed off too much cylinder pressure....just my .02.
Correction on my post about some Fastburns being iron.....I misread the catalog..they are 18degree racing heads with "fastburn" chambers....but are cast iron...my fault
Old Aug 26, 2003 | 02:32 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Porting is not critical in boost applications.. I'm partial to Dart Pro 1's
Chuck84TA
Jul 15, 2016 09:05 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
