Octane?
Old Sep 11, 2003 | 12:30 AM
MouseCamaro305's Avatar
Octane?
I ordered a nitrous kit for my zz4 350.
its got a slighty taller manifold (dual plane)
larger cam .510 .520 and the duration @ .50 is 230/236
the motor is a 10/1 compression with hypereutectic pistons and aluminum 58 cc heads. I'm running a street mechanical edelbrock pump through a demon 4 bbl 750 double pumper. l'm hoping to be able to run a 150 shot on it possibly on 93 octane. the motor will not run well if l pull any ignition advance on it.
beleive it or not the motor will run (very well actually) on 87 octane which l discovered on accident. l normally run 93 through it, and the motor NEVER hiccups or backfires.
l have a few questions. I can get my hands on 110 leaded for a fairly good price. the motor is completely mechanical, no cats, or emissions equipment. half and half 110/93 would make 101, my question is can leaded and unleaded be mixed and would aluminum heads, and modern (stock) valves tolerate the use of a leaded fuel?
Secondly, l have seen a product by NOS that is throttle position controlled that opens and closes the sollenoid from the reading it takes from the throttle position sensor. thats what I gather from it. This product goes against everything l know about sollenoids. Aren't sollenoids designed to either be fully open or full closed? Let me know your thoughts on that progressive system.
thanks alot guys
1fast91
Sep 8, 2015 01:48 PM
masonta
Sep 1, 2015 06:40 PM
Justin92GTA
Aug 27, 2015 11:16 PM
355tpipickup
Aug 13, 2015 07:35 AM
