Cure for broken cranks
Old Sep 21, 2003 | 06:06 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
i just got an idea and i dont know if anyone else has figured this out before me but...i have a lot of friends with blown motors and it seems like theyre always breaking cranks, even the good forged ones. it always breaks right before the timing gear, after the last bearing. i know its because the blower drive belt puts so much stress on the crank , so if you could somehow add another bearing on the tip of the blower pulley, wouldnt this make the crank much stronger? even if you could just put another belt on there linked to a free spinning pulley, as long as it was pulling down and counteracting the force of the drive belt pulling up on it, wouldnt that take the stress off? is there a mechanical engineer in the house?
Old Sep 21, 2003 | 11:08 PM
biggtime's Avatar
You can buy small block cranks with big block snouts..Or BDS sells
a front crank support. This also happens from not enough timing
Old Sep 22, 2003 | 02:55 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
if the belt was moved closer to the damper or if the damper was grouved it would help...i think
whipplle dose this on some kits
http://www.whipplesuperchargers.com/...sp?ProdID=1171
Old Sep 22, 2003 | 05:01 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have been seeing in the mustang racing classes for years - a strut rod with what appears at first to be a very odd heim joint on each end. but they are really needle roller bearings attached to both the front of the crankshaft and the input shaft on the blower. this strut's job is to prevent the tension applied by the belt from pulling the crank and blower shaft towards each other. I was unable to find a picture of one. just imagine a heim joint panhard bar from our cars made to fit between the crank and input shaft on the blower and the inside of the heimjoint actuall spins with the crank speed on one end and the blower speed on the other.
Old Sep 22, 2003 | 05:30 PM
biggtime's Avatar
Hey i have one of those on my harley open belt!
Old Sep 22, 2003 | 06:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
come to think of it I have seen them on harleys I wonder if the blower guys got the idea there first? If you have a pic post it to show what we mean.
Old Sep 22, 2003 | 07:16 PM
biggtime's Avatar
I don't have a pic handy.. ......I couldn't post it anyway!
Here is the link to their site though.
http://www.beltdrives.com/
Old Sep 23, 2003 | 11:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
they dont have a pic there of what I mean
Old Sep 23, 2003 | 11:51 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
AH HA!!!!!!!!!!!!!
Old Sep 23, 2003 | 11:59 AM
biggtime's Avatar
Whow! I don't think you would have enough room for it though.
Old Sep 23, 2003 | 12:23 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
nope
apie2546
Oct 16, 2016 02:24 PM
Reid Fleming
Oct 10, 2015 09:56 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
