Building a 87 TPI Vette Motor... Want to use nitrious
Old Sep 26, 2003 | 12:36 PM
GTA350JAG's Avatar
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
I have a 350 motor out of an 87 Corvette with 90K. I am swapping this motor in my 87 GTA (The GTA original motor is a 350) I am going to build it using a Lengenfeltr cam kit and super ram intake setup. I am also having the heads redone with new valves roller rockers etc. I now have saved up enough money and I want rebuild the entire motor with all forged parts, and get the fuel injection nitrous setup from NOS. I will also be getting my computer reprogrammed and accel 30lb injectors. Does anyone have any suggestions about what company I should buy from for the forged rebuild kit or did anyone do similar setup to what I am doing and can tell me about it?
Mods already done to my motor
MSD 6AL, MSD Blaster Coil, Eddelbrock TES ceramic coated headers, dynomax highflow cat, flowmaster 3inch cat back single outlet exhaust, March 3 piece power series underdrive pulleys, Holly 52MM throttle body, TPIS fuel pressure regulator, ram air hood with ram air intake setup
Old Sep 28, 2003 | 03:54 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
How much do you plan on spraying?
Old Sep 29, 2003 | 01:34 PM
GTA350JAG's Avatar
The kit is adjustable from 100-150 shot and I will be using it at 100.
Old Sep 29, 2003 | 03:36 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Dude, you can pray a 100 shot on a stock motor. Change the plugs for 1 step colder and retard you timing 3*. Then spray the **** out it.
Old Sep 29, 2003 | 04:26 PM
GTA350JAG's Avatar
ok cool, I was only wondering because I want to build a completly new motor and put forged parts in it but I guess it wont matter forged or not then...
Old Sep 30, 2003 | 09:59 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Don't get me wrong, forged internals will put up w/ a lot more abuse, but if don't plan on going bigger than a 100 shot, its not worth the time and money.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
