My 1991 Z's Procharged Destroked 400
Old 03-12-2005, 05:48 AM
  #101
B4Ctom1's Avatar
Car: 1992 B4C 1LE
sad thing is that if I cannot get the air piping around my P1SC that I want I might section the air intake tube throught the inner fender like others here at TGO have done. If I do that an inner fender will need minor reconstruction and repainting.
Old 04-23-2005, 06:24 PM
  #102
B4Ctom1's Avatar
Car: 1992 B4C 1LE
huge picture sorry:
http://www.outlawperformance.com/ima...r/DSCF0013.JPG
steering bushing to bearing swap from GM astro/safari
Warning! 7.25 turns lock to lock is not for the faint of heart, here is my to manual steering swap:
Old 04-25-2005, 10:58 PM
  #103
jamesd's Avatar
Originally posted by B4Ctom1
huge picture sorry:
can you give some more info on this? I'm guessing it's to make the steering smoother?
Old 04-25-2005, 11:24 PM
  #104
B4Ctom1's Avatar
Car: 1992 B4C 1LE
I only did the bearing swap because I was collecting the parts to make a nice double ujoint steering shaft without buying the flaming river shaft kit.
I could have used the stock shaft with little or no modding, but the stock shaft and the little tiny CV boot on the upper joint was shredded and icky.
Since I was going manual box I decided the little bearing and the double ujoints would make that 6.5 turns lock to lock a little smoother.
btw all I have to do is extend the shaft by 4" and re-clock it a few degrees to proper center the halves.
To intall the bearing only takes about 1 minute if you clean the grease off of the steering wheel shaft where it comes out of the fire wall to make the old bushing removal quick and easy (takes another minute or two.
hate to sound like an *** but its is true-er than true, you find a first gen astro/safari and simply take it off the end of the steering column where the steering shaft comes out.
tools you will need to get the bearing at the wrecking yard:
a 3/8ths ratchet with the 7/16" socket
7/16" wrench (just in case)
a hammer (just in case)
a couple flat blade screw drivers small and large.
1. take the steering box shaft upper off on the van so you can slide everthing off (use 7/16" to take out single bolt) and tap on the upper coupler (if needed with the hammer) to free it from its aged location. the shaft telescopes down so that you can pull it off.
2. use the small screwdriver to gently slide the "scratchy/grabby inverted star" retaining washer carefully to prevent breaking it or tweaking it beyond usability.
it might turn inside out but that is ok because it will still work in its new direction. be careful not to lose the little "wave" spring washer the it is holding up.
3. use the small screw driver to pull the big wire clip up and off
4. with a back and forth twisting motion pull off the little sheet metal cap
5. use the large screw driver to pull and pry the plastic bodied bearing retainer out of the tube and down the two inches of protruding shaft. if the shaft is dirty it will hang up a bit, if it is rusty it might hang up more.
now you have all of the parts in the picture on the right.
when you get home to put it on your car knowing what you do from pulling the parts off the van you will be a pro at putting the new parts on. very straight forward.
I recommend cleaning and hand packing the bearing with real grease (not just oil or WD-40) by hand through the narrow seam cracks (takes a few mins). To ensure a long and happy bearing life.
Old 04-26-2005, 02:46 AM
  #105
jamesd's Avatar
Thanks for the info. Did the steering shaft and u-joints come from the same vehicle(astro van)?
Old 04-26-2005, 02:50 AM
  #106
B4Ctom1's Avatar
Car: 1992 B4C 1LE
yes, I got the info from this post:
https://www.thirdgen.org/techbb2/sho...hreadid=185491
Old 12-31-2006, 12:57 PM
  #107
B4Ctom1's Avatar
Car: 1992 B4C 1LE
I won't be using any FMU's or reprogrammed GM ecm stuff, I bought a Bigstuff3 SEFI with a single wideband and data aquisition. I will be running it batch fire using a GM small cap style HEI distributor which will still allow me full individual cylinder fueling but not individual cylinder timing. I can change it later to crank trigger/sequential if I grow out of it, but for now that is how I intend to run it configured.
I am still making considerations as to the camshaft.
Old 12-31-2006, 03:50 PM
  #108
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
bringin this one back from the dead! well i hope things come together soon!
Old 01-10-2007, 08:38 PM
  #109
82TransAM_45's Avatar
Car: 82 Trans AM
Transmission: th350 turbo
what car does that as heaterbox come from? i want one because i dont run ac in my TA and id like to free up some room in my engine bay?
Old 01-11-2007, 08:56 AM
  #110
B4Ctom1's Avatar
Car: 1992 B4C 1LE
any ac delete thirdgen there are specific posts here on TGO search "heater box" or "AC delete" or "A/C delete"
Old 01-11-2007, 09:32 AM
  #111
Will's Fiero's Avatar
Originally Posted by B4Ctom1
Rods:
6.00 inch
H-beam
4340
bushed for floating pins
I LOVE the 4.125/3.250 combo.
If you have gotten pistons for a 406 w/6" rods, you could have run 6.250 rods. Eagle has those on the shelf.
Old 01-11-2007, 02:27 PM
  #112
Car: 82 Trans AM
ok ill take a look at that then about the a/c delete. thanks
Old 01-12-2007, 11:05 AM
  #113
BDR
BDR's Avatar
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
engine comp. looks good.
if you're still looking for a cam.. I bought mine from Doug Herbert (solid roller).
Alex
Old 01-12-2007, 12:35 PM
  #114
B4Ctom1's Avatar
Car: 1992 B4C 1LE
its funny that you mentioned that because Doug Herbert has some grinds I had forgotten about that I alwasy said would make stout street N/A or blower cams.
Old 01-12-2007, 10:23 PM
  #115
CrazyHawaiian's Avatar
Car: too many ...
So how is BigStuff3? You happy with it? I'm still saving up to buy one for my Z28.
Old 01-12-2007, 11:48 PM
  #116
B4Ctom1's Avatar
Car: 1992 B4C 1LE
We already installed it on one car at the shop and so far it seems awsome.
Old 01-13-2007, 05:48 AM
  #117
87IROC350's Avatar
Engine: 5.7
What did the Bigstuff3 run in price?
Old 01-13-2007, 02:47 PM
  #118
B4Ctom1's Avatar
Car: 1992 B4C 1LE
I can't say because it was mostly sponsored to me. Because of my help and relationship with the local shop who was trying to get enough units to "buy in" a bigstuff 3 dealership right away.
Old 05-25-2009, 02:06 AM
  #119
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: My 1991 Z's Procharged Destroked 400
What exactly happened, did you get the car together and running right, are you driving it, i know this is about as dead as they get but yea whats goin on here?
Old 05-25-2009, 11:21 AM
  #120
B4Ctom1's Avatar
Car: 1992 B4C 1LE
I don't mind the thread necromancy. Basically it is all I think about lately. It is summer, we have been streetracing again locally. My friend Aaron took his turbo street nova to the track a clipped off a 8.76 and 8.77 in the 1/4 at ~161 mph. I have no chance of going that fast without his turbo.
My house is my priority right now. There are so many things that need work. That car is way back on the burners. I got divorced and it threw everything crazy. My crazy work schedule is so undefined that I never know exactly when I am going to work. SO that doesn't help either.
The answer to your question is the car hasn't moved. I haven't turned a wrench on it. I did replace some paneling in my dining room with sheetrock though.
Old 05-26-2009, 12:45 AM
  #121
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Yea i saw that thread you got up about your friends Nova that thing is wild, but i hope you get everything sorted out. Hey look at it this way at least you do still have your job, i got layed off about a month ago. Keep your head high things will work out.
Linson
09-25-2021 07:55 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
ZekeThorpe
Theoretical and Street Racing
35
10-07-2015 07:30 PM
mcfastestZ28
10-05-2015 07:12 AM
dbrochard
Interior Parts Wanted
09-28-2015 07:40 PM
Quick Reply: My 1991 Z's Procharged Destroked 400
