Couple N2O ?'s
Old Nov 3, 2003 | 05:42 PM
gtpfbod's Avatar
Couple N2O ?'s
Im going to spray for my first time this weekend, just had a few questions. I will be spraying a 100 shot for now. 305 TPI with basic mods
1. Do i need to retard the timing for a 100 shot, and if so, how much?
2. Will TR6's do the job as far as spark plugs go?
Thanks!
Old Nov 4, 2003 | 09:24 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Depends WHERE your timing is as of right now. Stock is 6 degrees on a TPI engine. I ran 9 degrees roughly on pump gas and it was fine. With a 100 shot I backed it down to 5-6 degrees and it was cool. With the 150 shot I ran 4 and 94 octane still and it needs more octane and maybe a degree or two less of timing. Goodluck! It's FUN
Old Nov 4, 2003 | 10:45 PM
83 Crossfire TA's Avatar
TR6's are the right plug (full step cooler then stock) for a 350, but I believe that they are A LOT cooler then stock 305 plugs
Old Nov 4, 2003 | 11:50 PM
gtpfbod's Avatar
Thanks. I guess I will run at 5* of timing on 93 octane. As far as the Plugs go, what would work better? Autolite's?
Old Nov 5, 2003 | 12:01 AM
gtpfbod's Avatar
after some questioning looks like Im just eithier gonna go get some 1* cooler plugs are just run the stock ones..I let you guys know how it turns out. Thanks for the help!
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
