DFCO Issues? Please help
Old Nov 8, 2003 | 11:18 PM
rooster433's Avatar
I've car the car running on a 2 bar map sensor.. If i can get the damn decceleration fuel cut turned off it will be OK. Right now when you let off the gas (when rolling) the car goes to 4 degrees of timeing and cuts the injectors completely off.. I've never seen that happen on a 1 bar stock tune.
Old Nov 10, 2003 | 12:16 AM
83 Crossfire TA's Avatar
my crossfire car did that... what problem is it causing?
Old Nov 10, 2003 | 12:22 AM
rooster433's Avatar
Well.. its acutally shutting the motor completely down.
I emailed tunercat to ask if they could include this in the definition file. I think if i can disable it It would cure the problem.
I mean its bad.. It feels like someone turns the key off anytime you let off the gas, the cars warm and your at a good speed.
Old Nov 10, 2003 | 05:10 PM
rooster433's Avatar
resolved it..
Thanks to tunercat.. I wrote a email requesting a TDF with DFCO tables in it.. and bam here it is monday and the car is driving good as new
Old Nov 10, 2003 | 05:46 PM
so did you disable it all together or just make it a little more tame?
Old Nov 13, 2003 | 10:48 AM
rooster433's Avatar
I just made it a little more tame...
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
