Progressive controllers, which to use....
Old Nov 14, 2003 | 03:07 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Right now it looks like I've got 2 options. NOS and Jacobs. One sprays nitrous in relation to RPM and the other one is time based. I need to know how the time based one works. I drive a manual and if I go w/ a time based unit I want to cut off the N2o between shifts w/o it restarting from the lower setting.
Like when I shift into 4th gear I don't want the controller to think that I'm trying to launch the car from a dead stop.
Any suggestions about this?
Old Nov 19, 2003 | 11:56 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
ttt
Old Nov 19, 2003 | 01:14 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes dont lift the throttle between shifts.
read this and scroll to the part called the "big night of racing"
https://www.thirdgen.org/techbb2/sho...hreadid=199760
Old Nov 20, 2003 | 01:25 AM
83 Crossfire TA's Avatar
I don't see any good reason for a time based setup unless you have a race only car that has more traction then you need.
Old Nov 20, 2003 | 05:48 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I don't understand. I don't have traction. I was looking into ways to soften the blow and keep from spinning.
Old Nov 20, 2003 | 07:10 PM
Exactly my point…
So what if you loose traction? You let off the gas and the controller resets. Unless you’ve got a well sorted car that always sees the same conditions, can you predict what will happen 2 seconds in to every pass? How about on the street?
thunder57
Nov 7, 2015 02:28 PM
tmellott89
Oct 14, 2015 02:06 PM
BrianI
Oct 3, 2015 12:57 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
