will this ATI Procharger Kit fit my 92 Z28?
Old Dec 9, 2003 | 08:40 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
here are the details i know
ATI Prochrger for 86-89 Corvette Supercharger complette kit with intercooler $3400.00 (canadian)
i have a 92 Z28 with 305 TPI
Old Dec 9, 2003 | 01:31 PM
92Z's Avatar
92Z
The blower head unit will work, but you would require new brackets and tubing. The Thirdgen's use an offset intercooler like the one in the picture. It looks to be a 2 core. If you bought tubing from ATI you would have to tell them that, as the three core is longer and requires a different tube. You would also need the crank pulley and spacer. Hope this helps.
Old Dec 9, 2003 | 01:53 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
My guess is it would cost your more in the long run if you bought that kit and then bought the rest of the brackets etc. to make it work. You would be better off just buying the right kit for your car new.
Old Dec 11, 2003 | 05:56 PM
stevedave454's Avatar
Car: 91 S10
yeah 3400 isn't that great of a deal
Old Dec 12, 2003 | 01:13 AM
83 Crossfire TA's Avatar
I can't remember that the exchange rate is now, but isn't that within a few hundred $ of what you could buy a new setup for?
If the price was better it wouldn't be that big a deal to cut your own bracket and make tubing (weld, get a muffler shop to do it or even buy bends and rubber couplers and clamp it all together).
Old Dec 17, 2003 | 04:52 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
I WOULD NOT TOUCH THAT KIT. YOU CAN PURCHASE A P1SC KIT BRAND NEW FOR LESS THAN THAT. JUST DO A SEARCH ON ALTAVISTA OR OTHER SEARCH ENGINE FOR A COMPANY THAT SELLS ATI. THAT LOOKS LIKE A P600B, WHICH ARE THE BASE MODEL AND ONLY *** KNOWS IF IT EVEN WORKS.
MoJoe
Sep 15, 2015 12:50 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
hectre13
Aug 26, 2015 08:17 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
