Vortech Pulley size
Old Dec 30, 2003 | 08:02 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
Vortech Pulley size
I just bought a used Vortech SQ and was looking at the crank pully I got with it. It looks exactly like my crank pulley that is on the car. It's approx 7-3/4". Does any one know if this is correct, or do you know the size it should be? I asked Vortech but they don't have a measurement on it. Thanks
Old Dec 30, 2003 | 01:06 PM
Guest
Guest
Posts: n/a
Its the same part number as the factory part too... what a concept!
Yes, its identical.
Old Dec 30, 2003 | 01:46 PM
ostrich's Avatar
Car: 85 Iroc-Z
Thanks Madmax, I looked at the part number and it has a GM part number on it, that's why I was puzzled. I did a calculation on the impeller speed, do you know what size of pulley goes on the charger itself? I have 3 different pulleys from this guy? Thanks
Old Dec 30, 2003 | 02:08 PM
Guest
Guest
Posts: n/a
Not sure myself. I could measure mine, but I dont know if its the stock pulley or not. Maybe Guido can tell you that one.
Old Jan 2, 2004 | 12:46 AM
Guest
Guest
Posts: n/a
I should have replied earlier, but forgot.
The pulley I have is 3.5" I'm not sure if thats the stock size or not though, probably is.
Actually the installation manual lists the components and sizes, the stock size is 3.48"
Old Jan 2, 2004 | 10:41 AM
ostrich's Avatar
Car: 85 Iroc-Z
Thanks madmax. I have 3 pulleys all smaller than that. I did the calculation with the 7-3/4" crank pulley, but they will put me over the 50000rpm range. I'll have to look for a new supercharger pulley.
BDR
Nov 7, 2015 03:05 PM
Nervous2
Oct 8, 2015 10:53 PM
evilstuie
Sep 24, 2015 02:31 AM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
