carbed procharger buildup
Old Jan 14, 2004 | 07:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Hi, I've been planning out a new motor combo and after much research I'm almost deadset on going with an ATI Procharger P600B. However I have a few questions for you blower-experts out there... First off here is the combo I have in my head. Remember this is all in the very early stages I need to do way more research and planning:
Shortblock:
My current 355 which has TRW forged flat tops,
C&A forged 5.7 I-beam rods, ESP cast steel crank,
studded 4-bolt mains, all ARP hardware, Plasma moly
rings gapped for nitrous use
Cylinder heads:
I'm thinking either AFR 195's with 74cc chambers or Dart Pro 1
200cc's with 72cc chambers. With the AFR's my (estimated)
compression would be around 9.2:1 and
with the Darts about 9.4:1.
Camshaft:
I'm thinking something like Crane Powermax solid
grind: 288/298 Adv duration, 248/258 @ 050,
.500/.520 lift, 114LSA. This is just an idea, might consider
a custom grind or even a solid roller.
Induction:
Holley Strip Dominator intake manifold and
(possibly) my current 750 Speed Demon modified for a blow-thru
setup. EFI is out of my budget right now but most definately
sometime in the distant future so I don't wanna hear about it
Now, here comes the questions.
1) What parts would you change? (No I'm not going with EFI!)
2) How much non-intercooled boost do you think I could push on pump gas? I know 9.x:1 compression is slightly high for a blown motor but I'm guessing I could get away with 10-12psi safely on 93 octane?
3) I've seen some pictures and done plenty of searches. Everything looks like it will bolt-up without any major modifications. Am I correct? I have no power steering, AC, or anything to worry about.
4) Is the P600B a good choice for a motor like this or would you consider maybe a D1 series?
5) What kind of power do you think a motor like this could produce? Do you think my bottom end would handle it (considering good tuning)?
Thanks in advance. I'd really like to hear some opinions on a motor like this before I begin making it a reality
-Chris
Old Jan 14, 2004 | 09:03 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I dont say this often but you might go with a bit less camshaft. I wouldnt want to shift an I beam, i assume stock crank motor much higher than 6000 rpm on a power adder.
Old Jan 16, 2004 | 12:16 AM
Car: '89 IROC-Z
I agree about the cam... I'm leaning more towards the next-size down which is 238/246 @ 050. As you suggested, I'd also like to keep this motor's peak at or below 6000RPM.
Nobody else has any suggestions or experience with a carbed Procharger?
Thanks,
Chris
Old Jan 18, 2004 | 11:13 AM
BigL350's Avatar
I just went through what you're going through with my malibu's motor buildup. Everything on the bottom end sounds good. You may want to go with a CR that's a little lower if you plan on running 10-12psi w/o and intercooler, but it may work with aluminum heads. I'm running iron Vortec's so I went with 8.5:1. I'd have the carb sent out to a professional rebuilder that specializes in blow-through applications, like The Carb Shop and SDCE. That seems to be the one issue that everyone is in agreement on at the blow-through boards I go to. Part throttle driveability seems to be the biggest difference everyone sees. Another thing all the "pro's" agreed on is to go with a D-series blower, but I've read about people having succes with the P-1sc also. As you probably already know, you need a boost referenced fuel system. I went with a mallory regulator and A1000 Aeromotive pump. I havn't run the car yet with my new setup, so take it all for what it's worth. This is just the advice I used in builiding what I have. Check out The Blow-through Carb board and http://www.gmabody.com HTH.
Old Jan 18, 2004 | 11:59 PM
biggtime's Avatar
Without a intercooler you cannot run more than 8 or 9lbs of boost without detonation. some may argue you can, but most cannot. Also your carb is pretty big for your blow thru application.
Old Jan 19, 2004 | 12:53 AM
yeah my pro charger literature says that a 650 mech. secondary holley will handle a ridiculous amount of horsepower.
Honestly, I looked into a centrifigal supercharger setup and decided that nitrous was the way to go for me. My 350 with vortec heads, 10:1 compression, the XE274 cam and port work already blows the tires off at any speed in first, and will actually power brake driving 35 mph in 2nd gear. A well built sbc will make more power than the street will ever allow for, and at the track you can have more horsepower at the touch of a button . I would someday like to build a centrifigal setup, but it will be EFI.
Old Jan 19, 2004 | 01:00 AM
stevedave454's Avatar
Car: 91 S10
i wouldn't worry bout changing your intake, as it does not make "as much" of a difference on blown motors, and if your going to efi down the road then i wouldnt bother, also 10-12 psi non intercooled on 9.x:1 comp is pretty high, i'd say keep it round 6-8 psi untill you can get that intercooler, you will definately need one, even a little detonation and those i-beams and stock crank are done, also get AT LEAST a p1sc, if not the d1 series, might wanna take water injection into consideration too, theres a post on here from bottlefed, where he, and rooster433, talk about, and show pics of their home made systems, cheap and effective, but i personally would never consider it an alternative to an intercooler
http://www.jgstools.com/turbo/index2.html
if price is the reason to not get an intercooler cheack out this place, they got some good ones for $400-450, also check ebay, you can get em there for around $300, very good investment
Old Jan 19, 2004 | 09:21 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
might consider investing in a forged crank, prolly find a used one for less than $300, this company (www.ohiocrank.com)has a .010 under one for $295, look under the what's new section and also check ebay.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
