DS turbo manifold finished
Old Jan 18, 2004 | 10:48 AM
ta84-355's Avatar
Car: Trans Am -84
Engine: 355, Twin Turbo
Axle/Gears: 3.73 open
Well after spending a few more hours in the garage than on the sofa itīs finished. Itīs been a lot more work than I expected and Iīm not fully satisfied. But then again, itīs my first time welding.
Pictures can be found here:
http://www.itv.se/~a1003/turbo/exhaust/exhaust.html
For more info about the project, go here:
One manifold down , another one to go....
PS! Some of the pictures are linked to another server which are having some trouble right now. So pictures might be unavailable for a few hours at a time.
Old Jan 18, 2004 | 02:01 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Looks good, but.... your going to need to cut a scallop between #1 and #3 ports to clear the coolent sensor in the head. BW
Old Jan 18, 2004 | 08:24 PM
jon_volk's Avatar
my question is how the hell are you gonna route the drivers side downpipe? doesnt look like theres any room left for a good sized pipe.
Old Jan 19, 2004 | 01:43 AM
ta84-355's Avatar
Car: Trans Am -84
Iīm glad you asked, a 3" downpipe will fit nice. Hereīs a picture to prove it:
http://aldengard.lixom.nu/gallery/exhaust_parts/ds32
Itīll be a little tight for the sparkplug wires but it can be done.
A lot of thought has gone into the cylinder 7īs pipe, just to be sure a good sized downpipe can be used.
For a complete set of pictures of my exhaust project:
Iīm going to cut the headflange into 3 pieces so the temp.sensor wonīt be a problem. It was easier to build the header with one big flange than three short ones. I want to remove the "extra" flange material so it wonīt weight as much, but Iīll first mill the surface flat..
/Anders
Old Jan 19, 2004 | 06:37 AM
jon_volk's Avatar
/Anders
WOW thats a tight fit. changing spark plugs will be fun
Old Jan 19, 2004 | 08:25 AM
ta84-355's Avatar
Car: Trans Am -84
Well itīll be a little bit tight for the cyl 5 and cyl 7 when the downpipe is installed but besides that there is no problem at all reaching the plugs. Itīs actually easier to get to them with the turboheaders than with the Edelbrock 1 5/8 headers I had before, a lot easier.
As can be seen on this picture:
http://aldengard.lixom.nu/gallery/exhaust_parts/ds21
Only cylinder 5īs pipe is going under the head flange. but thereīs plenty of room for a plugwrench anyway. Iīm quite surprised over how much room there is, but then again, the manifold is quite wide and builds towards the master brake cylinder, hereīs a pic that shows the sparkplug clearance:
http://aldengard.lixom.nu/gallery/exhaust_parts/ds28
Tomorrow they will replace the server where my pictures are stored so itīll probably be offline for a day or two, Iīm sorry.
Old Jan 19, 2004 | 11:39 AM
Guido's Avatar
Car: 2000 Trans Am
Wow I really like the routing of the pipes! Its going to be hot for your plug wires, but it is managable.
Good job so far!!
Old Jan 19, 2004 | 01:34 PM
ta84-355's Avatar
Car: Trans Am -84
Thanks Guido, I really appreciate your comments. Due to the lack of a garage during the last two years I have been thinking about these manifolds at least a thousand times before I started to construct them.
But even though I had decided how to do it I had to change the plans slightly after buying the bends. But I'm quite pleased with the design.
Hopefully the plug wires will stay alive if I wrap the headers and make some heat shields, Iīll let you know lateron.
Thanks again, now itīs time to start on the other one.
/Anders
Old Jan 19, 2004 | 07:10 PM
87IROC350's Avatar
Engine: 5.7
Looks real nice. Any chance you can run the spark plug wires under the headers than back up towards the back of the engine? That just looks like a tight fit for you wires.
Old Jan 20, 2004 | 12:40 AM
ta84-355's Avatar
Car: Trans Am -84
Yes cyl 5 and 7 must be routed from the underside due to the with of the downpipe. It should have been a lot easier going with 2.25" or 2.5".
Thanks everyone for the feedback.
/Anders
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Linson
Sep 21, 2015 01:08 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
