What to do when i supercharge?
Old Mar 12, 2004 | 03:58 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Alright guys, i've decided to go with a Vortech Supercharger. The thing is however it is made for serpentine belt setup. Isthere any posible way to make it bolt up and work in the stock A/C Location.Since i'm deleting A/C completely i would like to do that. Would this work without having to convert to Serpentine?
Also, when i do this i think i'll get the supercharger, some headers, and what else should i get? What else would take full advantage of the Supercharger. I might do some intake porting also but i dunno.
Also i got a '86 5.0 TPI, with a full cat back system already(edelbrok), what kinda power numbers would i be looking in when i do this with some headers and porting?
Shane
Old Mar 12, 2004 | 04:25 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Just swap to a serpentine setup.. then make sure to bolt some 18's on the back for traction. BW
Old Mar 12, 2004 | 05:02 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
d00d, leave that alone, that was what, 8 months ago. Old times. I'm for real d00d.
Do i really have to switch to serpintine though? Is there any way around that?
Shane
Old Mar 12, 2004 | 05:22 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
I couldn't resist.. hehe
Without designing and building custom brackets, plumbing, and fabrication of a custom v-belt/serpentine belt pulley (an old paxton pulley might work), swapping to the later belt setup would be easier, faster and cheaper in the long run. BW
Old Mar 12, 2004 | 05:46 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok can i get away with just buying serpentine brakcets, or do i gotta get all new belt driven things? I heard/saw you gotta get new alternator, A/C, waterpump, everything. Is this true?
Shane
Old Mar 12, 2004 | 05:52 PM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Old Mar 12, 2004 | 05:55 PM
Car: '87 Mustang LX
Engine: 5.0
OMFG! lol. I remember that!
Old Mar 12, 2004 | 06:23 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
d00ds please, i appologiesed a long time ago for that. Come on. You guys, hopefully can get over it and we can become friends. I was young and immature. Well 7 months ago is a long time for me,i matured so muhc about cars its not even funny.
Shane
Old Mar 12, 2004 | 06:26 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
but for real, how do i convert to serpinine system? Do i just need the brackets, or do i need everything again.
Old Mar 12, 2004 | 06:28 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Shane
You'll need all the accessories too. Or at a minimum you need the AC comp, alt pulley, water pump pulley, reverse rotation water pump, power steering pulley, serpentine crank pulley, and brackets.
BW
Car: '87 Mustang LX
Engine: 5.0
kidrcth: On the day that you stop saying the word "d00d" I promise to leave you alone.
Old Mar 12, 2004 | 06:30 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
d00d a conversion(brand new) cost' $546.95. I think thats way more expensive than a custom bracket.
Shane
Old Mar 12, 2004 | 06:36 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Shane
You can find what you need for a ton less.. well under $200 complete.
Check the classifieds here, Ebay, your local trader... start asking around. BW
Old Mar 12, 2004 | 06:44 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6755
88-92 Camaro Serpentine Bracket LH IROC Z28 RS
88-92 Camaro Serpentine Bracket RH IROC Z28 RS
heres the brackets...
Old Mar 12, 2004 | 06:54 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nah d00ds a custom bracket will be made........ If it aint broke dont fix it.....
Shane
Old Mar 12, 2004 | 07:04 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well guys here is a pic of the kit(all of it cost $2999.00). What do you think will have to be done to that brack? I might be able to just lengthen it or shorten it to make it fit where the A/C compressor was, Wont I?
Thanks,
Shane
Old Mar 12, 2004 | 07:20 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Thanks,
Shane
Well considering it bolts to serpentine type brackets, and uses serpentine type accessories.. it ain't worth a damn.
Your going to spend $3K on a charger.. and gripe on buying the correct belt arraingment.... geez.
BW
Old Mar 12, 2004 | 08:03 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
actually that supercharger is gay compared to tjhe ATi procharger i'm looking at now. Will bring my stock 305 up to 210(my cat back adds some power) + 85%(15-20psi) = 388. But i'll expect somewhere in the 350 range. This kit is much better(intercooled) and its only $3555.95.
I know your wondering how they can give you that much psi, i dunno either but they warentee it for 1 year and the engine for 3 years so i have confidence.
I could goto the cheaoper one with a less powerful intercooler for $3055.95. Will give my little 305 p to 336 HP. I like the 388 better however. So i like that number much better.
https://www.rpmoutlet.com/atifbodytp.htm
here is what they say about them superchargers(prolly already read it though,
With ProCharger technology, reliably adding big horsepower to your engine is a lot easier than you may think. Intercooled ProCharger systems utilize exclusive features and proven technology to deliver reliable 50-100% gains in horsepower and torque while running pump gas. ATI is the only company that has put stock 5.0's, LT1's, 4.6's and LS1's into the 11's, and routinely delivers 12-second ET's to completely stock TPI applications running pump gas. ATI is also the only company that guarantees the best performance gains. Nothing else even comes close! For modified street applications, ProCharger technology delivers 10-second ET's with the least amount of engine modifications - and with the supercharger still under warranty. These systems are 100% complete, and daily drivability is unchanged. ProCharger superchargers also provide the coolest engine intake air temperatures ever, and are so durable they are backed by the industry's best warranty coverage. For example, the ProCharger 14 psi 5.0 Mustang system is backed by a one year warranty, while no other supercharger company will warranty 14 psi for even one day. Superior products yield superior results.
I think i like the idea of this cause i get to keep thw awesome low end torque of my TPI stuff. Which is completely awesome.....
Shane
Old Mar 12, 2004 | 08:04 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i guess you make a good point sopendign $3.5k on something then complaining about $400 is pittyful. hmmmm......lol
Shane
Old Mar 12, 2004 | 11:52 PM
nightrider87's Avatar
you need to do a lot more research. its not possible to run 15-20lbs on your stock compression. nor would i being doing it much with a stock bottom end.
find a setup used for the belts, they already told you that. trying to convert a bracket you are paying big bucks for is not a bright idea.
Old Mar 12, 2004 | 11:53 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
yeha i can get a used kit with a/c and everything for $200. so that'll do.
Shane
Old Mar 12, 2004 | 11:54 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
theysaid i could run 15-20PSI, why cant i according to you? While this kit is in use i'll be building or saving up fopr a nice 350 to replace it. So that'll do.
Shane
Old Mar 12, 2004 | 11:59 PM
ok. don't do any research, bolt that 15 lb pulley on and go.
I wouldn't be going near something as potentially dangerous as a supercharger unless I knew every damn thing there is to know about them. I've been researching my turbo project for about a year now and I think i finally know exactly what i need to know.
Old Mar 13, 2004 | 11:06 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
nightrider87 don't let him get to you. In a matter of minutes you figured out that he is just wasting space, he is not capable of blowing his nose let alone blowing his engine, look at the rest of his posts and you will understand !
Old Mar 13, 2004 | 11:34 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
alright guys,i understand the stress a superhcarger puts on an engine, i relaly do. But i dont care aboutt his POS 305. While the supercharger is on the 305 a replacement 350 will be built ready to go in. That way io can start with a new engine. I think i might be able to get a good yeah left outta the 305 before its end comes.
Shane
Old Mar 13, 2004 | 12:04 PM
Its not the stress it puts on an engine that is the big issue here . Its that it is not possible to run that much boost on that much compression without race gas or water injection. end of topic.
Build youself a nice healthy 350 and be done with it. People who come into this forum without a shread of knowledge are just window shoppers so i guess i don't have to try help you not blow your engine, cause it won't ever see boost.
On another note, FLRTIN1 do you have any pics with the hood on your car? I'd be interested in seeing how the blower looks.
and also, what are you getting out of that 305 with the 6-71? Thanks,
Jay
EDIT: found your website
Old Mar 13, 2004 | 12:20 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well, if you say so, but the sight syas its made for "1988 - 1992 TPI F-body 5.0li and 5.7li System" SO my guess is that they had already thought of this stuff my friend. It is made for the 305 and the 350, therefore must be able to handle the compression.
Shane
Old Mar 13, 2004 | 12:26 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
here is the chart they got which system would be better?
Year Description HP Gain Boost Level Computer/Ignition Modifications Price
88-92 HO 2-Core Intercooled with P600b or P-1SC* 60-80% 9-12 psi Not Required $ 3,055.95
88-92 Stage II Intercooled with D-1 or D1-SC** 85+% 15-20 psi Not Required $ 3,555.95
Polish finish for ProCharger Satin Finish Standard $ 195.95
Upgrade to 3 core Intercooler (from 2 core) 750 hp Max. $ 255.95
Upgrade to P-1SC from P600-B $ 243.95
Upgrade to D-1SC from D-1 $ 100.95
Which system would be beter suited for me to be able to walk over a 4th gen? The 15-20PSI or the 9-12PSI. All i wanna do is walk over a 4th gne, thats it. I will not do any major engine mods beucase well, i'm not experienced with taking apart chevy engines(i took apart a lawn mover but thats it).
heres a paragraph from them-
The revolutionary new SC ProCharger models are the first and only gear-driven centrifugal superchargers to feature self-lubrication. The SC models share all of the design elements, which deliver the record-setting durability and performance of ProCharger competition superchargers, and are quiet and street legal. The P-1SC is the most popular automotive supercharger, and is the only self-contained supercharger durable enough to be backed with a 3-ear warranty and powerful enough to harness the benefits of intercooling. The patented design eliminates the need for oil lines, or the need to puncture the oil pan, thanks to its exclusive oil pump. The pump aerates the oil to create the oil mist lubrication required by the precision double bearings and gears. This oil pump (aeration pump) does not require priming at start-up, and oil changes are required only every 6,000 miles.
SC ProChargers also feature:
An internal step-up ratio of 4.10:1. (eleminates belt slip)
Cast with permanent molds for the highest quality and finish.
Supports up to 1200 cfm and 825 horsepower.
Billet, Helixed or Radial impellers.
Oil System Self Contained.
Shane
Old Mar 13, 2004 | 12:34 PM
flrtin1's Avatar
Engine: S/B
Shane you just contine to show your ignorance go ahead and buy what you can't afford and do what you want to screw your car up and why bother people when you know all the answers, you are the know all :hail:
Jay
I have some on my web site from the mid 80's with the small blower on it but I don't have any with the cowl w/671 (it was a pos unlimited hood). Here are some current ones of the factory composite hood still need some finishing and I have to figure out a paint design for it
Old Mar 13, 2004 | 12:42 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
alright guys, i'll leave yaalone, was just starting this thread for the simple answer of the serpintine setup. Then it transformed and you guys are getting amd at me? dont seem fair. But anyways.....
Shane
Old Mar 13, 2004 | 12:58 PM
kidrcth, i will still try to help you. I don't want to see you pissed off with ATI because you listened to their website and interpretted it incorrectly.
Those systems imply they are for a TPI 305 or 350. Yes, fine. What that really means is they will fit on those engines. They have the right brackets, and they have the right intercooler loaction and plumbing to run with our cars. However, the 15-20 psi kit is deffinately designed for an engine that has had some work done to it. Now, the 9-12 psi kit is much more ideal in your situation but I wouldn't waste my money on a small supercharger just yet.
Build yourself a nice forged internals 350 with 8.5 or less compression if you want something as crazy as 15-20 psi. Mind you, that will do more than stomp all over 4th gens. It will stomp all over everything lol.
If all you really want is to beat 4th gens, and you plan to build a new 350 anyhow, then you should stay naturally aspirated. For your mild power goals, a supercharger is just mindlessly overkill in terms of expense. I do realize that if that's your goal now, it'll change after one season of being that fast but thats why they invented nitrous and bolt ons. Build either a 350 or a 383 and since you seem to have money to burn, throw a set of AFR 195s on top of it. Get yourself a holley stealth ram or even a converted LT1 intake to go on top. mate that with a cam around 230 to 235 duration and .550 lift or more and you'll be deep in the 12s if not easily in the 11s. That'll be much cheaper than buying a supercharger and building a stout bottom end for it. Later, if 11s aren't good enough which they won't be after a while , you can throw a nice nitrous setup on top of it and hit low 11s or maybe even 10s depending on how much you spray. This is depending on how much you drop on your rotating assembly to begin with though too. Forged is always better but you can spray 200 on hypers if you really wanted. Keep in mind you'll need to upgrade everything from the engine back too heh.
cheers,
Jay
FLRTIN1, the blower looks surprisingly good with the way you've done the hood. With the reputation our cars have for being white trashy, i thought a roots blower might really add to that effect with it sticking through the hood. How much of it could you cover up with a 6 inch cowl? Doesn't look like too much lol
Old Mar 13, 2004 | 01:24 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
could i use a Recon Performance Engine, 350 short block?
here are the specs summit posted on it,
Recon's Remanufactured Chevy 350 short blcok features a 3.48" stroke Scat cast steel crank, 5.7" Scat I-Beam rods, Federal Mogul 9.4-1 compression (with 64cc head) flat top pistons, sealed power rings, and Clevite bearings.
RCN-71850RSM each $1,595.95
From the sounds of the engine construction it sounds like a good base to me. Stell crank, I-beam rods. Sounds like its sturdy. My step-dad, he was a mechanic back in 87-89(until her joined the navy), said that these were some stout engines and that this is what i should be looking at for a replacement. If i do supercharge, which i will, i am keeping the TPI for the fact is has awesome low end torque numbers.
Tell me what ya think....
Shane
Old Mar 13, 2004 | 01:26 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
if i put some L-98 heads on that thing i could be doing pretty good right? I can port them pretty good, and thre supercharger will do the rest, they are also pretty cheap now....
Shane
Old Mar 13, 2004 | 01:29 PM
flrtin1's Avatar
Engine: S/B
Jay,
lol I think I would still have to have a pretty big hole in a 6".
I built this motor for a friend of mine a couple of years ago to put in his TA I thought maybe we could get it under his scoop but he decided to put it in his truck before I was done and sold the TA.
People make comments when I don't have the hood on but IMO the car looks better that way
Old Mar 13, 2004 | 01:31 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
or go with the same engien with heads already on it for double the price,
Chevrolet: 350, 350 HP, assembled engine
This Remanufactured, dyno-tested Chevy 350 features a seasoned 4-bolt block (honed with deck plates), cast crankshaft, Keith Black hypereutectic pistons, I-beam connecting rods with ARP bolts, Melling high volume oil pump, a Crane 222/234 degrees duration hydraulic camshaft, Clevite main and rod bearings, and Fel-Pro gaskets. You also get World Products Sportsman II heads, Pioneer 1.5 ratio rockers, an Edelbrock Performer RPM intake, a Dynagear double roller timing chain, an oil pan, valve covers, and a timing cover. Dyno sheet included.
Since i wont be going carb i can sell the intake, for some money, but it is still quite expensive, however from what i hear they are the shizznits.
Shane
Old Mar 13, 2004 | 01:52 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
what should i do guys??????
Old Mar 13, 2004 | 03:05 PM
If you want an engine without a supercharger, both of these sound fine. However, if you're still set on supercharging, try make sure everything is forged, ie crank, a good set of I or even H beam rods, and forged pistons that will give you low compression with the heads you want.
You can generally put your own short block together for much less than buying one if you want it all forged. I think with the cheaper stuff (cast and hyper), a pre-made short block isn't too bad in terms of cost efficiency.
Old Mar 13, 2004 | 03:07 PM
On another note, L98 heads are garbage. even the aluminum corvette ones. You could pick almost any other head and do better in your engine build up.
Old Jul 8, 2005 | 05:38 AM
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
If its power you want then you really dont need a supercharger. unless its because of the sound it makes when it spools up. but before you can get that cool sound out of a supercharger the engine will need to be built for it, a supercharger wont give you that much power if the engine is all stock.
may I suggest a engine since you said you dont have much building exp. try SDPC2000.com insert this part number SDZZ465B in the blank below where it says search by part numbers. you should find a sdpc custom built crate engine that is ballenced and blueprinted and ready to run here is the spec's .
Specifications
SDPC Part Number: SDZZ465B
Manufacturer: Scoggin Dickey Parts Center
Horsepower : 465 @ 6100 RPM
Torque : 430 @ 4600 RPM
Compression Ratio : 10.1:1
Camshaft Duration @ .050 : 234 / 242
Camshaft Lift, I/E : 0.575 / 0.595
Cylinder Block : 4-Bolt Cast Iron, 1pc Seal
Crankshaft : 3.480, Forged Steel
Cylinder Heads cc : 62cc, Fast burn Aluminum
Intake Manifold : Performer RPM Air Gap
the price is not half bad at $5,700.
and if you want more power you could either go with a turbo setup and NOS , or just nos, you could have up to 600 hp and just woop azz all day long and still have a reliable car afterwards. and the best part is even the cops wont notice you as much than if you were riding around with that big supercharger pokin out of the hood . waving at every cop miles away.
Old Jul 8, 2005 | 05:49 AM
Car: 86 trans am
and also if you have deep pockets then you can get a custom built crate engine built and completly installed by this .www.lingenfelter.com
scroll down the page and check out the video of the lingenfelter LS2 c6 427 twin turbo engine, it puts out 951 hp. now that would be sick in a 3rd or 4th gen fbody car.
Old Jul 9, 2005 | 02:10 PM
how many people driving 3000 dollar cars like ours can say 5700 for just an engine is not that bad?
460hp for 5700 dollars...you've got to be kidding me.
Old Jul 10, 2005 | 12:39 AM
  #42
CrazyHawaiian's Avatar
Car: too many ...
Wow back from the dead. To answer one of the original questions, what else would take full advantage of the supercharger, I'd say an intake and cam swap. The previous owner of my 91Z28 had a S-Trim V1 Vortech kit installed on the stock L98 and one of the biggest problems I see is the mismatch in powerbands. The TPI/Stock Heads/Cam setup powerband stops around 4,800 to 5,000 rpm and the blowers powerband (aka full boost) starts around 2,800 to 3,000 rpm. That only leaves you with about a 1,800 to 2,000 rpm range where the combo is making power. I can literally feel the power drop off. If you swapped the cam to a boost friendly cam with a 2,000 to 6,000 powerband and changed the intake to something like the HSR you would pull hard all the way to 6,000 rpm, 3,000 of them at full boost. The rest of that Vortech kit takes care of the fuel management (in a lame way, but it works) and the MSD box gives you some safety with the timing retard per psi of boost. After adressing the cam/intake I'd say concentrate on the drivetrain (stall/shiftkit) and suspension (traction). Exhuat is a must.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
