went 9.74@140.59!!
Old Apr 30, 2004 | 11:19 PM
NOSFEDGTA's Avatar
went 9.74@140.59!!
Well I got a chance to try the new fuel system this past weekend and went a 9.74@140.59 on the juice... I also got a new best of 10.84 on motor@126.72
I could have gone faster, but my alternator took a shi! in the burnout box. I ran it anyway and lost fuel pressure again. It only had 8.lbs of pressure on hte nos side"I run a 10psi kit" so I think I think the next time out with the right fuel pressure I might be able to go some 9.60's or 50's.... I am very happy with the car and hope to get to the 9.50 range soon !!
Old May 1, 2004 | 09:47 AM
Damon's Avatar
Congratulations! 9s is some kinda quick number. First time in the 9s with this car?
Old May 1, 2004 | 10:20 AM
NOSFEDGTA's Avatar
2nd time first was a 9.98
Old May 1, 2004 | 12:03 PM
strokeronthesause's Avatar
GREAT TIMESS!!!!few questions
1. what was your 60 on that pass
2. eight mile time and mph
3. what size nitrous jet and fuel jet
thanx
Old May 2, 2004 | 09:24 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Re: went 9.74@140.59!!
Excuse my lack of knowledge, but when I ran my nitrous systems, I could only tell the pressure out of my bottle(800-1100 psi) How do you measure how many psi you were putting out at 8-10psi?
Are you talking lbs/min? If so what are you using to measure it?
Old May 2, 2004 | 09:31 AM
he means to the fuel solenoid, 8 is on the leaner side 10 being very safe.
Old May 2, 2004 | 09:39 AM
BADDEST305's Avatar
Car: 1991 z-28
Engine: 434--654hp---601 torque
Transmission: ATI POWERGLIDE
Axle/Gears: mose 9" / 411 gears
very nice! what shot did you have in there? i'm trying to get a guess of what a 200 shot will get me running 10.34 n/a. well keep up the fine job bro that thing is moving!
http://mywebpages.comcast.net/baddest434/1040small.avi
Old May 2, 2004 | 10:52 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
BADDEST305,
What happened to your 305?
Old May 2, 2004 | 11:50 AM
BADDEST305's Avatar
Car: 1991 z-28
sorry for the hi-jack nosfedgta
RMK i came into a few bucks from a settlement so i invested half of it into my car and the other half into my house to keep the wife happy i still have a few bucks left that i'm using to help acheive a 9 sec n/a pass thats my goal!
Old May 3, 2004 | 12:01 PM
NOSFEDGTA's Avatar
Re: GREAT TIMESS!!!!few questions
thanx
60 ft was a 1.42
1/8th was a 6.24@111.79
my nos jets are very diff than others I am using a tnt system.
Old May 3, 2004 | 12:04 PM
NOSFEDGTA's Avatar
I had the 250's in.. my car is not reacting the way it should on the juice right now. I am not sure if it is the fuel isue I have been having or what.. My friends car goes 10.50s all day on motor when he sprays 200 he goes some 9.40's and 50's. He is running an n/a cam too. I run a nitous cam on a 112 lbs. I have to figuire out whats going on with mine. He picks up more than I do with jsut a 100 shot to my 200 shot.... I better get busy before he gets to far ahead of me
Old May 3, 2004 | 03:50 PM
83 Crossfire TA's Avatar
QUOTE]Originally posted by NOSFEDGTA
my nos jets are very diff than others I am using a tnt system. [/QUOTE]
Huh, how are the NOS gets different then TnT?
I'm assuming that his setup is otherwise similar?
First place I would look for a difference would be the exhaust (anywhere from the valve to the tailpipe… if he has more flow somewhere it would explain the difference, exhuast flow makes a very big difference with power adders), and otherwise it's possible that his setup is just better tuned…
Old May 3, 2004 | 04:50 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Nice work. Welcome to the club.
Old May 3, 2004 | 07:36 PM
NOSFEDGTA's Avatar
"Huh, how are the NOS gets different then TnT?"
I meant the jet patterns. The use diff paterns for their hp levels. Their spray bar is very diff as well. the holes are smaller with many holes unlike a nx system which uses 4 large holes per side.
First place I would look for a difference would be the exhaust (anywhere from the valve to the tailpipe… if he has more flow somewhere it would explain the difference, exhuast flow makes a very big difference with power adders), and otherwise it's possible that his setup is just better tuned… [/B][/QUOTE]
same heads, rods, crank, block, pisotns etc. my cam is a 265-276@50 dur with 6.40-649 lift solid roller with a 112ls.
his cam is 258-264@50dur with 602-609 lift on a 110ls.
both heads flowed 300int and mine actuall flowed a little more on the exhaust.his220 mine almost 230
same headers same exhaust same gear. he runs a spool i run a locker and his car is 200 puinds lighter. please dont say its all right their either.
the only BIG diff is our converters. he runs an 8in 5300 stall, I run a 4600 custom billet nitrous converter. Now I coudl see it being a big deal on motor but not the juice.....
Old May 4, 2004 | 12:10 AM
You know, I hate to say it but I think there are enough little things going on that pretty much explain that difference. Fix the alt/fuel probem and the biggest difference will be the weight…
Old May 4, 2004 | 06:50 PM
i understand the maps would be different but i would like to know the size of the actual nitrous jet and fuel jet.
Old May 4, 2004 | 09:25 PM
NOSFEDGTA's Avatar
its a 58 fuel and a 74 or 76 nos.. i cant remember right now I will look in the morning...
Old May 5, 2004 | 04:07 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Wow, I didn't even realize you're not far at all from me.
I assume this was ran at reynolds? Send me a PM next time you go, I'd be interested in watching.
Old May 5, 2004 | 08:46 AM
NOSFEDGTA's Avatar
no prob.. did you go to the gafba shootout a fw weeks ago??? I was there with a few others from the milledgeville eatonton area...
BCdawg57
Aug 18, 2007 11:01 PM
kylez28
Theoretical and Street Racing
Apr 9, 2006 11:33 PM
Yellow87Bird
Feb 6, 2004 02:57 AM
stevenmh
Jan 1, 2001 08:32 PM
stevenmh
Jan 1, 2001 02:54 PM
