Introductions. . .
Old May 27, 2004 | 10:27 AM
SWT Racing's Avatar
Car: '72 Chevy Vega GT
Engine: Twin Turbo 353" SBC Blowthrough
Transmission: PowerGlide
Introductions. . .
I just wanted to make a quick post to introduce myself. I was led here through some tech article links that were posted on turbomustangs.com, where I post fairly regularly. I was really impressed by the tech articles, so I decided to register. I also recognize a few of you, like Guido and 83 Crossfire TA, from other forums/lists.
Although I do not own a 3rd Gen, I do own a Chevy. I'm running a water-to-air intercooled twin turbo 355 in a '72 Vega GT. I'm also blowing through a carburetor.
At any rate, just wanted to introduce myself. I look forward to discussing power adder tech with y'all.
Old May 27, 2004 | 12:16 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Welcome to the TGO Forums SWT.
Old May 27, 2004 | 12:45 PM
bad_turbo's Avatar
'bout time you made it over here!
Old May 27, 2004 | 12:46 PM
Guido's Avatar
Car: 2000 Trans Am
Howdy! Im the boss err uhm yea of this corral. LOL
Welcome to the forum.
Old May 27, 2004 | 01:53 PM
SWT Racing's Avatar
Thanks guys! Looks like I might know a few more people around here than I first thought.
bad_turbo,
Whereabouts in SoCal are you?
Old May 27, 2004 | 02:18 PM
bad_turbo's Avatar
simi valley, aren't you just south of me?
Old May 27, 2004 | 02:39 PM
SWT Racing's Avatar
I'm in Huntington Beach. I'll actually be up in your neck of the woods this weekend picking up my block and crank from the machine shop.
Old May 27, 2004 | 07:06 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I just made a post under yours in "show your power adder"
Old May 29, 2004 | 06:47 PM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Re: Introductions. . .
Hi SWT Racing, and welcome to thridgen!
I just read that you have a Chevy Vega, I do not own one, but I'm making a turbo setup for a customer who owns one with the V8 swap. It's incredible, the headers he currently have in his car won't let him remove even the starter without removing the headers and engine at the same time. Same thing happens with the tranny, can't be removed without removing headers and engine. Did you had this problem when running headers, if you did run headers before going twin turbo, just curious?
Thank you, and welcome again to 3rd gen.
Old May 30, 2004 | 12:26 PM
SWT Racing's Avatar
Re: Re: Introductions. . .
Thanks BBS.
What type of motor mounts does your customer run? There are three types: stock V8 Monza, Don Hardy, and Hooker/Trans-Dapt. The Hooker type is on the front of the motor and mounts to brackets on the framerails. The headers for this type each have the rearmost tube exit the engine compartment and co around the frame. They are 3-piece slip-tube headers. The other two types of motor mounts mount to the factory motor mount pads on the engine and frame, and the headers are routed just like a standard header. He probably has this type if he has that much trouble with the trans and starter. With the Hooker swap kit, I would have to drop the headers to change starter or to remove the oil filter. I used to just use a remote mount for the filter. I could get the trans out with the headers on though. Because the headers are 3-piece, they come off very easily if they need to come out.
