Vortech, Code 33, max gm/sec issue??
Old Jun 24, 2004 | 10:21 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I have been living with this issue for a while now, but I am finally fed up with it.
I have a vortech super charger with an ATI intercooler. Over the last couple years, I have been throwing a code 33. I can be barely in the throttle and the car acts like I just shut off the spark. If I keep the throttle in that place, the ses light comes on. If I get out of the throttle at that time and get back into it, no light and the car responds. I can also stab the throttle when this happens and it responds fine with no light. It appears that this occurs only under 2000 rpm's and it does not matter if it is hot or cold; open or closed loop.
I have read about the factory setting for setting a code for excessive air flow under 2000 rpm's. Could this be the issue?
I have an OTC 2000 scanner. If I hook it up and watch the MAF readings, what am I looking for when this occurs?
I have swapped MAF's and relays to no avail.
Any suggestions would be great!
Old Jun 24, 2004 | 10:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
have you tried to adjust your TPS?
Old Jun 24, 2004 | 10:41 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I have checked the TPS and it is set to factory specs. Should I deviate from those settings? Let me know your thoughts.
Old Jun 25, 2004 | 09:18 PM
Guest
Guest
Posts: n/a
Adjusting the TPS is kind of a band aid fix to the problem. If you set it on the low end (like .35) it should come close to fixing it, if not fixing it.
Yes, need to change the chip. Its probably set at 45 gm/s and thats usually too low... even on just a cammed car.
Old Jul 6, 2004 | 11:08 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
No luck, I set the tps to .32 and it seemed to work well on the low end, 45 mph and less but on the high end, it fell all over itself again.
Any more thoughts? I will entertain burning my own prom as a last resort.
Thank you!
Old Jul 13, 2004 | 07:19 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thank you!
Switch to '749.
-- Joe
Old Jul 14, 2004 | 07:26 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
A step ahead of ya, I found two 7749 ecm's in the salvage yard, the map and plug are on the way. I found the prom part number, but am looking for a speed density vortech 350 chip for ease of use.
I am ordering the knock sensor today.
see ya,
Mark
Old Jul 14, 2004 | 08:53 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Originally posted by anesthes
Switch to '749.
-- Joe
Joe did you ditch the 730' that you converted to run the $58?
If you did just curious why?
Old Jul 15, 2004 | 07:32 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm running $58 (actually $60 now) in my '730 btw. no need to actually get a '749.
As far as running the modified version of $8d, no i'm not running that anymore.
-- Joe
Cornholio7979
Sep 20, 2018 02:31 AM
gta90
Sep 15, 2015 04:00 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
