NX express Hitman nitrous system. Good or Bad??!!
Old Jul 31, 2004 | 07:51 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
ok people what i want to know is if this kit is a good kit with good quality peices. This will be my first time installing and using a nitrous system and I have read that its for the N20 impaired but is it good quality. Is it better than the Holley NOS Super powershot brand? Any help will be appreciated.
Old Jul 31, 2004 | 10:19 PM
onebadwagon's Avatar
i have one new in the box, overall it "LOOKS" like a great quality kit, much better than anything in it's price range. IMO.
just waiting on the time to do a carb swap on my trans am, and then it's on like donkey kong.
Old Aug 1, 2004 | 10:12 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
The Hitman is NX entry level nitrous kit, compared to other brands entry level kits the hitman is far better in quality than the rest. This will be a great kit for you if its your first nitrous install, simple and straitforward.
Old Aug 2, 2004 | 01:35 PM
Car: 89 camaro RS
Well I just ordered one about 15 minutes ago so I cant wait for it it to get here. I am gonna also get a fuel cutoff safety switch or something like that, and a aircraft style trigger so that when i have it too the floor I can activate it myself. Isnt that what that switch allows you to do?
Old Aug 2, 2004 | 08:49 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Manual switch is about the worst thing you can do in my opion, to much room for error. Get a switch to arm the system and then get a micro switch that activates it at full throttle. Thats about the easiest,cheapest way to make it idiot proof.
Anyway welcome to the wonderful world of nitrous,now get ready to buy all the acc. your gonna need for it.
Old Aug 2, 2004 | 09:14 PM
Car: 89 camaro RS
Opps my bad Superman,
thats what I meant about the aircraft style ARMING switch....
you summed up what my dumbassed phrasing.
What kind of acc do I need to run this beast?
Old Aug 3, 2004 | 03:21 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Genx-2 upgrade kit
Old Aug 3, 2004 | 05:31 AM
Car: 89 camaro RS
ok I looked through jeg's and I found this, is this the GENX 2 kit http://www.jegs.com/cgi-bin/ncommerc...59&prmenbr=361 cause look at the part number it says 744-GENX-2
Old Aug 3, 2004 | 01:07 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Yep that kit will do nicely. That with the hitman kit will have you a very nice entry level nirous setup. You will be pleased with the NX parts and performance.
Old Aug 3, 2004 | 01:12 PM
Car: 89 camaro RS
alright cool. I cant wait to get get this kit installed. How long does installation usually take? I am also thinking about getting an air/fuel monitor as well just to be safe.
Old Aug 5, 2004 | 10:33 AM
Car: 89 camaro RS
Ok I just recieved my kit today. Well its looks good and all but I dont see how I am supposed to activate this kit. I dont have a WOT switch in the kit and I was looking in the GENX 2 kit and didnt notice on in there either??? Am I supposed to buy that and an arming switch seperately???
Old Aug 5, 2004 | 10:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what no nitrous company ever tells you is that you dont get EVERYTHING in the kit.... they usually leave out saftey devices in the name of lower cost.
im **** about nitrous. i like my motor too much to blow it up...
if it was me, i would get a nitrous mastermind... it has the fuel switch, revlimiter that shuts the nitrous off first, pulls timing, and is a window switch. but you do need a aftermarket ignition to use it (like MSD-6A or similar.)
at the very least, get a window switch, WOT switch, and a good arming switch.
Old Aug 5, 2004 | 11:10 AM
Car: 89 camaro RS
I know this is stupid but what is a window switch? What WOt switch should I use that will fit on my holley 4150 carb?
Old Aug 5, 2004 | 11:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A window switch turns on between a pair of engine speeds which you can usually program in some way.
Old Aug 5, 2004 | 12:28 PM
Car: 89 camaro RS
oh ok. does anyone have any pics of a nitrous system like this one? I was reading my instructions and it said that I need an adjustable fuel pressure regulater for the nitrous system and it says do not connect the N2O systme regulator through the carb regulator. But I ran across this little NOTE:Hitman systems are designed to operate with stock mechanical fuel pumps without a regulator. Does that mean I dont need a regulator for the nitrous?? I know I should need one for the carb. Am I correct on that?
Old Aug 6, 2004 | 11:48 AM
Car: 89 camaro RS
alright guys I figured out all of my ?'s so I just edited the posts.
Old Aug 8, 2004 | 07:48 AM
Car: 89 camaro RS
Old Aug 14, 2004 | 09:14 AM
Car: 89 camaro RS
But I do have one last question. Does the genx 2 kit have a relay for hooking up the system or is that ANOTHER thing I have to buy seperate? any help will be appreciated.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Apr 9, 2016 10:20 PM
mustangman65_79
Aug 7, 2015 09:55 PM
