supercharger with stock computer tuning
Old Aug 14, 2004 | 10:20 AM
blowntransam's Avatar
well i have a rebuilt 305 in my 86 trans am and i just converted to serptine belts and im ready for a supercharger i have been looking at the vortech and procharger do they come with computer chips or not also has anyone on the board ran a supercharger with a stock computer and how did it run
any help would be great.
Old Aug 14, 2004 | 12:56 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i have a 1988 camaro supercharged with a paxton stock chip idles ok with 24 pound injectors times are 12.71 at 111mph on street tires.
Old Aug 16, 2004 | 10:10 AM
KS91Z28's Avatar
You can run a supercharger on a stock computer to a point, after that you will have to start doing some custom tuning for injectors and stuff like that.
Old Aug 17, 2004 | 01:13 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm running the Vortech S-Trim with the included FMU unit. As far as I know my ECM is completely stock. Like KS91Z28 said, the FMU unit will work up to a certain point. It will only account for the boost increases. If you modify the engine itself (heads,cam, etc) then you might want to look into re-tuning the ECM.
Old Sep 4, 2004 | 04:37 PM
Toneyb35's Avatar
Car: 91' Z28 Vert
Engine: 305TPI
Transmission: 5 speed
Are you satisfied with your paxton. A buddy is trying to sell me his, practically new. For my 91' vert 305TPI...
Old Sep 4, 2004 | 11:14 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
those are some decent times , the trick flows work pretty good? I will have to pm you some time so I don't highjack this post
Old Sep 5, 2004 | 11:37 AM
antoine's Avatar
on dr i think it will run low in the twelves maybe i will have a chip made.one more thing is you don`t have to have the best stuff to run good times buying afr,prochargers etc.i like the paxton it is working good for me.they do have the vr-4 upgrade for 500 dollars and you will be getting 12-15 psi of boost.still running the first trickflows
Azrael91966669
25
Jun 20, 2017 04:04 AM
toronto formula
Nov 10, 2015 06:17 AM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
