Oil Cooler? Hot climate & SC'er...
Old Aug 30, 2004 | 11:58 PM
92GTA's Avatar
I live in the CA desert and it's very hot all summer long, when I install my ProCharger I wanted to install an oil cooler.
Do I need one? I use RoyalPurple and I was told that this kind of oil does not really need a cooler, that it will hold a consistant temp when it gets hot and never really get too hot. True or B.S.?
I once saw a pic of Willie's oil cooler and it looked perfect. What kind is it? We both have the exact same weather and I'm also going with the dual intercooler setup...
Old Aug 31, 2004 | 07:22 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I didn't need one with the turbos until I got about 15 minutes of hard road racing track time. On the street, oil temps would always be about 20 deg hotter than water, even during the 90 deg summer temps in New England. Get an oil temp gauge, and if you start seeing numbers above 300, then worry about an oil cooler. I assume you're running synthetic RP oil? They're fine below about 320 degF, from what I've read, although at that point, the viscosity is much thinner. For instance, the Z28tt idles at about 35 psi cold, 20 psi normal hot, and 10 at 340 deg temps.
Old Aug 31, 2004 | 08:08 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
My oil cooler is a Hayden kit in which I used the sandwich adapter and aluminum oil tubes. I discarded the rubber hoses and used braided lines instead.
Old Aug 31, 2004 | 08:12 AM
Willie's Avatar
Also, I replaced the included oil cooler with a Perma-Cool frame rail unit. This pic was taken when I had my single 3-core intercooler, which I no longer have.
Willie
Old Sep 1, 2004 | 04:52 PM
92GTA's Avatar
Thank guys!
I'll install an oil temp guage for next summer and see what happens. Not a huge deal for me because I expect summer '05 to be the last for this engine so I can try different things. If no cooler was bad and it gets too hot, no big deal because I'll be rebuilding it in the fall about a year from now anyway.
I really like that Perma-Cool frame rail unit, I like the looks and the position. You don't happen to have a P/N would you? Where is your oil filter Willie? Can I get that sandwich adapter by it's self? I can have a local shop fab me up the steel tubing and braided lines....
Old Sep 1, 2004 | 07:04 PM
Willie's Avatar
My oil filter isn't on because I took these pics when I was installing the cooler. I think you can buy the sandwich adapter alone. Let me look over some paperwork. I'll see if I can find any info, part numbers and such.
Willie
Old Sep 1, 2004 | 07:29 PM
92GTA's Avatar
:hail:
Old Sep 1, 2004 | 09:45 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Here is the Perma Cool info:
http://www.permacool.com/Catalog/Cat_page15.html
And adapters:
http://www.permacool.com/Catalog/Cat_page28.html
I am in the process of installing a big oil cooler now. If you have long tube headers, check your clearance with the sandwich style adapters. I had to toss that in favor of a filter relocation style unit.
Old Sep 1, 2004 | 11:56 PM
92GTA's Avatar
Thank You! Looks like I'll order P/N's 1004 and 185....
What is a good online souce for buying these parts?
Old Sep 3, 2004 | 09:39 AM
bbunting's Avatar
Car: 1990 IROC Z
I usually shop at Summit or Jegs.
here is a picture of the racing oil cooler pn prm-501 that I mounted between the Spearco intercooler and Be Cool radiator:
You might also consider a competiton style mount that comes with -an fittings, and means buying fewer adapters and higher flow.
http://www.permacool.com/Catalog/Cat_page34.html
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
