Changing oil in a Paxton ball drive? what to use how often?
Old Sep 12, 2004 | 02:07 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
What grade? How often? 6psi ball drive paxton...i have no paperwork and all my research has yielded nothing....
Old Sep 12, 2004 | 08:03 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you are supposed to use special oil of some sort and paxton sells/sold "paxta-trac" fluid you should be able to find some using a google search. I thought they used some sort of ATF but I cant say for sure. If they do then I would be curious to see how "Type-F" would work.
Old Sep 13, 2004 | 06:48 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
DON`T USE PAX-TRAC FLUID WILL MAKE THE SUPERCHARGER OVERHEAT BECAUSE IT IS A SYNETHIC OIL AND WILL MAKE THE ***** SLIP.USE ONLY TYPE F TRANS FLUID AND CHANGE 3,000MILES OR TEN RACES.NO B&M TRICK SHIFT TO
Old Sep 14, 2004 | 07:06 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Paxton also went so far as to say that you should use FORD BRAND type F...NOT Valvoline or other brands...Supposedly the other brands could have some additives that could cause them to slip>>> I dont hknow how true it was...
Paxta Trac...LOL....I ran that and never had a problem...Iusually mixed it with type F... That Blower ran HOT no matter what you ran in it..Hence why they sold oil coolers for it..
AND for alll the haters that say it overheated the blowers I ran it straigt up for years...started mixing in the end after paxta trac was hard to come by... I purchased my paxton in July 1996>>> To this day the blower still works perfect>>>second owner still has it... IT HAS NEVER BEEN REBUILT... It was a FREAK..
Old Sep 14, 2004 | 10:50 AM
Cameron's Avatar
Car: 1985 Z28
wait wait are you saying that it uses oil or tranny fluid /boggle I was told by paxton tranny but the guy hadn't ever seen one
Old Sep 14, 2004 | 11:40 AM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
It uses FORD TYPEF ATF (tranny fluid)... BUT valvoline and others make a TYPEF... ORIginal Paxton company specified FORD brand only because of additives in the fluid of aftermarket brands...
OH and BTW..change intervals...I changed mine EVEY time I did an oil change..
Old Sep 14, 2004 | 11:56 AM
Cameron's Avatar
Car: 1985 Z28
Thank you Kenwood, very helpful! Your an asset to thirdgen
Old Sep 14, 2004 | 11:57 AM
Cameron's Avatar
Car: 1985 Z28
oh btw on rebuild kits, how hard is it to rebuild one? Or should I just switch to a gear driven? Everyone seems to be hating on the ball bearing =/
Old Sep 14, 2004 | 12:03 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
I bought mine in 1996>>>> A friend of mine now owns the blower.... TO DATE its never had a rebuild...MINE is/was a freak...
Guido blew up 3 in a matter of about 50 miles... My car despite having waaayyy less in the mod dept was waayyy faster..
Mine was built by the original paxton company/owners.. Once The company started to split as I understand it the whole company went to hell along with their knowledge/quality control...
Someone psted on here a while back about a company that did rebuilds for HALF that of paradise wheels>>>paradise wheels now owns all of the old Paxton ball drive service/units... I just dont remmebr who it was>>> I also remember reading here about a guy who rebuilt his himself>>> I NEVER took mine apart...Never had a reason to...
Mine outlasted my stock bottom end, rear end, and transmission... ..
As far as switching to a gear drive>>> its probably a GOOD idea down the road... I had a Paxton and S-trim vortech at the same time... Just the amount of POWER it took to turn the paxton versus the s-trim was reason enough to switch.. you can feel it spinning them by hand>>>big time...
Old Sep 15, 2004 | 12:44 AM
antoine's Avatar
i rebuilt mine myself
Old Sep 15, 2004 | 12:53 AM
Cameron's Avatar
Car: 1985 Z28
whats the process parts needed? PM me if you like I'd really appreciate it.
Old Sep 15, 2004 | 02:09 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Old Sep 15, 2004 | 10:09 PM
antoine's Avatar
does it matter about caps lock or not was helping out a thirdgen this is not school we are men not school teachers. by the way i can show you about caps lock in person b4ctom1.
Old Sep 15, 2004 | 10:31 PM
Cameron's Avatar
Car: 1985 Z28
better it was in caps, so I know that PATRITRAX IS NOTHING BUT SH##
Old Sep 15, 2004 | 10:51 PM
antoine's Avatar
cameron thanks,they have a forum called www.superchargerhelp.com go down click sn-series and they talk about paxton rebuilds.
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
