where to find flanges
Old Sep 20, 2004 | 10:32 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
for my new quad turbo setup in the elco
jon
Old Sep 23, 2004 | 01:36 AM
jocww's Avatar
the turbos are ct-12a so hopefully they will spool faster than 1 or 2 big ones
Old Sep 24, 2004 | 12:04 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
mite have to make your own :shrug:
Old Sep 24, 2004 | 12:19 AM
jocww's Avatar
how hard is that gonna be
Old Sep 24, 2004 | 12:50 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
That all depends on whether you have access to/skills to use a mill. If you don't, i'd give up and just buy them (if available, if not have them made). If you do, making them is very easy (for a JY caliber setup that is). I just laid some paper on the flange on the turbo, traced over it to get the lines, then transferred that shape to a piece of 1/2" scrap steel and cut it on a mill.
Old Sep 24, 2004 | 02:38 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
http://www.jgstools.com/turbo/index2.html
these guys and others have bunches!
http://stores.ebay.com/Forced-Fabric...enameZl2QQtZkm
Old Sep 24, 2004 | 04:49 PM
stu
Guest
Posts: n/a
Exactly what flanges are you looking for? If all of your surfaces are flat, then you won't need a flange. A lot of people like to have a gasket between the wastegate and the dump tube because of the frequent and large temperature changes.
Old Sep 25, 2004 | 03:07 PM
jocww's Avatar
i know nothing about turbos my friends getting rid of 4 of them and i said ill take them now i just have to set them up some how and he said i might need flanges. is 8-9 psi ok with hypertutenitc kb pistons and a stock cast crank
Old Sep 26, 2004 | 12:52 AM
jocww's Avatar
heres my cam specs intake 267 at .444lift
272@.444 lift
duration is 210 216@.50
runs out at about 4400
Old Sep 26, 2004 | 10:54 AM
Mike-91 Formula 350's Avatar
Not a good sign on trying to set up 4 turbos.
Old Sep 28, 2004 | 06:11 PM
jocww's Avatar
yea iv been hearing that alot
Old Oct 6, 2004 | 12:16 AM
jocww's Avatar
turbo hats are they that hard to make also can i make a air box type
Old Oct 6, 2004 | 11:43 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
No and yes.
Old Oct 6, 2004 | 01:44 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
http://www.superiorairflow.com/extreme_velocity.htm
Old Oct 6, 2004 | 05:08 PM
jocww's Avatar
whats the difference between o ring and gasket. also are those prices good prices
thanks
jon
Old Oct 6, 2004 | 05:44 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
o-ring and gasket is personal preference
those are a hundred or two less than the ATI ones
although the new ATI one has a special air dam in it to prevent the air signal in the carb from getting screwed up by the rushing air
Old Oct 6, 2004 | 11:40 PM
jocww's Avatar
what does the air damn look like
Old Oct 7, 2004 | 12:24 AM
jocww's Avatar
yeeeaaaaaaaaa 1080 wish i could do it on my snowboard. anyway my next question is that these are all rounded why is that ive seen vortechs and they seem to be more squared or with more angles is there a reason
Old Oct 7, 2004 | 01:39 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
it merely is an obstruction right in front of the air hat inlet that forces the air to flow into the carb from the perimeter of the hat as opposed to just tumbling in from the inlet.
Old Oct 7, 2004 | 07:52 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
You can also get the turbonetics carb hat for about $85 in cast aluminum.
Old Oct 7, 2004 | 01:40 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
really?
Old Oct 7, 2004 | 06:22 PM
jocww's Avatar
what does the turbonetics one look like. i just think that it looks kinda funny with no angles
Old Oct 7, 2004 | 06:33 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
http://www.ctfba.com/ss/finale04/DSC00887.jpg
Like that.
Old Oct 7, 2004 | 08:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
wow how can I get more info on that car in the picture? it looks like what I have visualized.
Old Oct 8, 2004 | 12:17 AM
jocww's Avatar
that looks sweet now i demand more pictures
Old Oct 10, 2004 | 03:33 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I've had this for oh... last 5 years or so, although the single plane intake & throttlebody hat went on this spring (as the super ram came off).
http://www.skulte.com/turbo.html
Old Oct 11, 2004 | 12:00 AM
jocww's Avatar
so how much for that hat
Old Oct 11, 2004 | 01:34 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Old Oct 11, 2004 | 11:12 PM
jocww's Avatar
yea ima dumbass but i was wondering if u were gonna sell yours sorry about the confusion
Old Dec 6, 2004 | 08:16 PM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
anybody have a part number for that? Carb hat for 85$
Old Dec 6, 2004 | 11:59 PM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Damn them. Now they come out with it Sounds like what we might need to clean up our part throttle lean spot....
Old Dec 7, 2004 | 12:03 AM
I second that one...
Properly sized, a nice twin setup will spool just fine and make gobs of power. And, will be a LOT easier to set up. Hell, we're getting full boost by 3,500 rpm with twin 60-1's on a 383. Perfect for us, that's where the cam starts to work anyhow....
And yes, 8 psi will work on hypereutectics, we've been running that for half the summer now with no issues, although, we do have a forged crank. Just keep a watchful eye on your air fuel. Hyper's like to disintegrate when pushed too far. A wideband will be your new best friend
Breazlan
Sep 25, 2015 11:20 AM
Ranbo108
Sep 9, 2015 12:20 PM
NiG
Sep 7, 2015 11:25 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
