Mild turbo setup & Hypereutic pistons...
Old Sep 21, 2004 | 08:42 PM
MartinCadek's Avatar
Very mild turbo setup (at least compared to what some of you are doing), single turbo, ~5psi, cast crank, hypereutic pistons
what do you think ?
I did a quick search but got 0 results for anything related to hyreutic pistons...
Old Sep 21, 2004 | 10:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have run up to 12 psi on cast pistons, up to 8 or 9 is safe.
https://www.thirdgen.org/techbb2/sea...der=descending
here is a good one from that list:
https://www.thirdgen.org/techbb2/sho...hreadid=214262
Old Sep 22, 2004 | 07:43 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
I would say no problem as long as you stay away from engine knock.
Old Sep 23, 2004 | 03:25 PM
Damon's Avatar
Yeah, detonation is the killer. That means very modest compression and not getting greedy with spark advance if you're going to run pump gas.
I'm running 5 PSI from a roots blower into my 383 with KB Hypers and they've stayed alive for almost 2 years of weekends. My compression is still a bit too high for a roots blower (8.6:1 - I shoulda tanked it down to around 8:1) and I am limited to about 26* of advance at WOT before detonation on pump gas. Over 28* and I start blowing alminum dust off the piston faces due to detonation. I'm currently laying 390 to the rear wheels through an automatic trans.
With a turbo (especially intercooled) you could almost certainly run the same compression as me, more spark advance and make more power than I do while still being less prone to detonation, all else being equal.
86Firebird86
Dec 26, 2015 07:21 AM
BDR
Nov 7, 2015 03:05 PM
customblackbird
Oct 1, 2015 04:30 PM
Doobie52
Sep 11, 2015 06:19 PM
Stryker412
Sep 7, 2015 09:11 AM
