Super charger/compression
Subscribe
Sep 22, 2004 | 08:15 AM
This is the supercharger that I plan on using.What compression would be best.I plan on using afr 195's but not sure what compression to use.I want to use pump gas with the most psi possible.http://proficientperformance.com/Mer...&Store_Code=PP
Reply 0
Sep 22, 2004 | 09:27 PM
8 to 1
Reply 0
Sep 22, 2004 | 10:39 PM
Reply 0
Sep 23, 2004 | 12:28 AM
Quote:
Originally posted by Cameron
i'm running 9:1 /shrug
I'm a noob
Reply 0
Sep 23, 2004 | 05:46 PM
I'm a noob
Yet faster than the guy running 8:1
-- Joe
Reply 0
Sep 24, 2004 | 12:01 AM
Quote:
-- Joe
Reply 0
Sep 24, 2004 | 05:32 AM
Re: Super charger/compression
Quote:
You need to realize something that escapes people. These setups were designed for STOCK cars with STOCK compression ratios.
Building a durable, high performance forged slug motor, then dropping the compression ratio to LESS than your stock static ratio is just plain stupid..
Run factory compression, build a free flowing exhaust, which includes head porting, and learn to tun with the '749.
-- Joe
Reply 0
Sep 24, 2004 | 06:39 AM
9.8:1 and iron heads. I did not want it to be a dog not in to boost.
Reply 0
Sep 24, 2004 | 07:32 AM
Quote:
With the 7.5 and the 3.33 what is your impeller speed!?
Damn. Sounds nice.
I'm redoing my motor this winter. Gonna go with a smaller chamber, around 9.7:1 c/r.. S-trim.
-- Joe
Reply 0
Sep 24, 2004 | 09:27 PM
I run 9.5:1. ran pump gas with 9lbs no problem.
Blownss has 9:1 14lbs on pump gas.
Both cars are intercooled
Reply 0
Sep 25, 2004 | 12:52 AM
So with a decent cam,Afr 195's 12 psi,forged bottom end and a ported tpi set up,any ideas on horsepower and torque?I know I can't get an exact but I want a good idea before spending the cash.I am trying to stay ca. legal.
Reply 0
Sep 26, 2004 | 02:34 AM
What cam should I use for best hp and torque while staying ca. legal?
Reply 0
Sep 26, 2004 | 10:38 AM
Something that makes the most power, and is 50 state legal.
-- Joe
Reply 0
Sep 27, 2004 | 01:23 AM
yeah,thanks
Reply 0
Sep 27, 2004 | 06:26 AM
yeah,thanks
Well what else would you like me to say?
Keep your air and cat functioning. Mass uses the same emissions as california. I passed with flying colors on my 560hp setup.
-- Joe
Reply 0
Sep 27, 2004 | 07:19 AM
What size cam are you using?
Reply 0
Oct 2, 2004 | 09:04 PM
I've been running 9.3:1 stock swirl port iron heads and 9-12 psi depending on belt slippage with no problems for 4-5K miles. I live in central FL where air temp is in the ~90 everyday and water temp struggles to stay below 220*.
I would think AL heads and good/smart tuning should see 10:1 comp and 15 psi easy on pump gas. Think big intercooler or other forms of detonation control.
Reply 0
Subscribe
