Where to plumb single fogger nozzle?
Old Oct 10, 2004 | 09:40 PM
IROCBlueZ28's Avatar
I recently purchased a universal NOS kit that has a single fogger nozzle hp from 50-125. Where should I plumb this??? I used to have a plate kit for my corvette, but this kit came with a fogger nozzle and I have a few ideas, but really need some guidance! I want to have it somewhat hidden...if possible. If not, I was thinking of tapping into the plastic air box, but really, I"m not sure where to put it?
HELP :shrug:
Old Oct 11, 2004 | 09:48 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I take it that since it is a single nozzle kit it is a dry system? If this is the case then you will want to mount it as close to inline with the TB as possible. Now, I'm not sure of the exact routing of your intake(seeing as how you have a super on it). If it is at all possible (regarding clrearance) you could drill and tap your intake duckting from the bottom and disguse the N02 line with split plastic wire tubing. With a dry system, as long as the nozzle is pointed up the intake, it'll work. Closer to the TB the better. In your case though, I 'd try to put it between your TB and the H2O injection.
Good luck, and enjoy the "throttle in a bottle"
Any more questions, just ask.
~Max
Old Oct 12, 2004 | 11:21 AM
the kit is a wet system. the fogger has a soleniod for the nitrous and the fuel like my old plate kit. I want to be able to use it with or with out the superhcarger on.
Old Oct 16, 2004 | 11:16 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
when i was running nos with a nozzle i had it before the throttle body.
Old Oct 17, 2004 | 02:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
in the bellows in front of the TB and use one of these so it doesnt fall out. the bushing next to it is shown a NX shark nozzle but you get the idea.
Attached Thumbnails Where to plumb single fogger nozzle?-shark-nozzle-bushing.jpg
Old Oct 17, 2004 | 09:58 PM
biggtime's Avatar
With the supercharger you want it on the inlet of the blower, but dry.
Old Oct 17, 2004 | 10:30 PM
Where exaclty do I put the nozzle? in the bellows in front of the TB, I'm not exaclty sure where your talking about? Also, My kit is a wet kit that has the soleniod's for nitrous and fuel...???
Thanks for the help you guys!!!:hail:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
