Head Gasket Thickness
Old Oct 20, 2004 | 06:37 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Whats the min gasket thickness you folks would run with an iron headed 355 @ 10-12psi boost?
I'd like to get away with an .020..
-- Joe
Old Oct 20, 2004 | 07:16 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'd look at two different things. Piston to deck clearance and compression ratio. Mainly quench distance (piston to deck). The recommended range for the most detonation resistance is .040-.045. Keep in mind that stock small blocks come with a piston to deck clearance of .025, so from there, you have to take into consideration....any passes taken off the deck, piston domes and dishes. Those are about the main things. Also rod lengh and wrist pin height can play a role if you start getting exotic.
Old Oct 20, 2004 | 07:27 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Piston recomends a deck height of .022, which is what I'm planning on decking the block too. The piston is a TRW 2256 flat top. (http://store.summitracing.com/defaul...t=trw-l2256f30)
I'm hoping for a .020 gasket, to get the compression, and quench area where I want it. (9.37:1 c/r)
The more quench area, the more it helps fighting detonation, no?
-- Joe
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
