loud superchargers
loud superchargers
ok...so. i know this might be a stupid question, but which centifugal supercharger sounds most like a turbo (assuming they do at all). id like to know because i dont wanna go through all the plumbing drama of a turbo but i really like the whistle of a turbo...i figured since a centri. s/c has an impeller it might sound like a turbo. but yah, let me know. o and dont tell me to juss go get a turbo pleeze.Thanx guys.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Stupid question, Yet I have some advice, perhaps the bigger pulley you have it on which makes it work harder creates the whine you want. or perhaps just buy a ****ty S/C that has its bearings going out that will sound whiney enough for ya.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I never heard an supercharger sound like a turbo they have their own sound is a whine caused be the gears in side the supercharger sounds similar to having a timing gear opposed to having a timing chain/belt I think ATI, Vortech has the blower kits that will give you the whine but most company's are going with silent drive superchargers for the sleeper effect
I dont think this is a stupid question. I have a Vortech S-Trim. It does a good job at pissing off the neighborhood. Friends of mine describe it as sounding like a Jet when cruzing by. IMO turbo's and S/C's have different sounds. But if you want a loud S/C, Vortech makes some pretty loud ones (as long as its no the SQ model).
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well after I changed my D1SC blower pulley to a smaller one I found it made that turbo sound some what and I'am not talking about gear whine, don't get me wrong it ain't no turbo but it sure sounds kewl as hell.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: loud superchargers
-- Joe
buy a P600b from prochargeer, has to be the noisest one i ever heard. Oh and the faster you turn it the more racket it will make.
If you don't care for performance why don't you put one of those annoying gear drives on?
Car: Maybach
Engine: KA24DE-T
Transmission: M5
Car: 1991 RS
Engine: Procharged LT1
My p600b is virtually quiet after 2 grand. Below that, and it is obnoxious.
Also, about the comment using the bigger pulley to make the s/c work harder, it is the other way around. The smaller the pulley, the faster the s/c is spinning.
As far as the topic goes, I don't know of any s/cs that sound like turbos.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
roots type blowers have a distinctive whine ive heard
Car: 1985 Iroc-Z
Transmission: t-5
roots style blower are definatly loud. As for centrifugal blowers my friend has a novi2000 on his fox body mustang and it is noisy at idle and low rpm's until he romps on it then it just kinda of blends in.
Car: 89 IROC
Engine: 350 CI Tuned Port
Transmission: Automatic
Axle/Gears: 3:45
A lot of the "traditional" blower sound in a roots comes from the cogged belt. I ran a B&M with the serpentine belt and it was completely silent. Put a cogged belt setup on something and you will hear it.
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
I have a grandprix gtp with a m90 supercharger I can vouch for them having a loud whine.. I get alot of "wtf" looks.. it does have a 3.4 pully tho.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
As BigTTime said. Get something like a Pete Jacksons gear drive. the specifically machine them for more "noise". Sometimes though, with a gear drive, your knock sensor tends to pick up frequencys from them.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im just like you though. I love the sound of a forced induction. Everytime i hear some type of charger going by i get chills down my spine.
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
speaking of that douse S/C sound chip
sorry, douse (any one have a)
Car: Used to drive a camaro
I'll have a sound clip this spring. 4Bolt Forged/balanced Eagle 383 (1pc rear seal), DART Iron Eagle 215cc 72cc heads, custom ground Comp Cam, harland sharp RR's, ATI P1SC (14lb pulley),TPIS Bigmouth,SLP Runners, BBK 58Twinn,60#FI with custom '749 Bin, SLP 1-3/4 non-air headers to true dual 2.5 H-pipe/catback into bullet long tube mufferls (similiar to B4CTom's). Wew, alot of things in the past 2 years. I am looking at (2) things currrently (flying someout out to test tune). Local shop may not give me a deal where I would say buy 4 hours and get 5. The local ricers have eaten up alot of local shops time. I'm venturing into more and more of doing 100% of everything myself. I'm even welding my exhaust now!
luvofjah
Sep 26, 2015 08:28 PM
I've cut back to a single and moved the whole smash to my truck.
