what dizzy with an 8/71
Old Dec 3, 2004 | 12:37 AM
jeff350's Avatar
I have been told that no distributor will work with a mooneyham 8/71 blower,and that i would have to run a front drive.
I don't want to get a smaller blower because i already have the 8/71 i,m sure i have seen cars with 8/71's with normal dizzy,s.
Any advice would be helpfull.
Jeff.
Old Dec 3, 2004 | 11:22 AM
AFBCamaro's Avatar
Car: 1991 Camaro RS
Engine: Blown 355 Small Block
Transmission: They always break!
Its true you cant use a standard distributor with some FEW 8-71s (depending on manifold positioning etc and blower casting). Most blowers when you go from 6-71 to 8-71 are usually longer in the front only so you wouldnt really have a problem.
I would get a manifold for it and mock up to a standard distributor and see if you can get away with it. Most likely you can, thats the general rule of thumb with 8-71s. Buy a BDS manifold they sit a little further to the front than mooneyham ones (specially the mooneyham competion series manifolds they sit way back).
If not what you will need is an offset distributor unlikely but can happen. Talk to BDS about one in the unlikely even you need one
Old Dec 3, 2004 | 07:52 PM
jeff350's Avatar
Thanks AFB i'll give BDS a call and see what they have to say.
Thanks again.
Jeff.
junkcltr
Aug 2, 2019 11:12 PM
school boy
Oct 22, 2015 11:47 AM
italiano67
Sep 22, 2015 08:42 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
