Nitro on TBI ?s
Old Dec 23, 2004 | 09:44 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Nitro on TBI ?s
Ok, I want to get an entry level nitrous kit for my 92 RS, it has the 305 TBI, stock bottom end and 140,000, still running strong.
I was wondering, I have a throttle body spacer, would I have to get a different one for the nitrous, or could I just drill out and tap the one I have?
Also, I've read that a stock 305's bottom end can take 100 shots pretty well, with good gas, but will it be alright for my engine with 140 thousand?
Sorry for all the newb questions, Thanks for listening.
Kyle
Old Dec 24, 2004 | 09:53 AM
PhilM's Avatar
Car: Accepting applications...
I used an NOS kit on my old 305 TBI. The kit plate uses spray bars to help the dispersion of the gas. If you could duplicate that setup, you could make a plate out of a spacer. Of course the N2O plate acts as a spacer anyway. I think it would be easier to just use the NOS plate.
As for the engine, I had over 200,000 on my 305 and was hitting it with a 120 shot, and it never winced. If you do everything right (follow the instructions, make sure you have enough fuel), you won't hurt the engine at all.
There are more myths about nitrous then facts.
Old Dec 24, 2004 | 01:46 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
thanks for the information.
What do you mean by enough fuel? Are you saying to make sure the engine isn't running lean?
I was just wondering, cause I didn't want to waste 120 on the spacer for nothing, I guess i could sell it to a friend.
I would like to learn as much about this as possible before I make any decisions, thanks for the help,
Kyle
Old Dec 24, 2004 | 04:15 PM
PhilM's Avatar
yes, be sure you have adequate pressure and flow. I think the kit I had called for 15-20 PSI under WOT. The stock pump in my car did the job with a 100 shot, but above that it was a little lean. you might want to invest in an aftermarket pump or a booster pump.
Old Dec 24, 2004 | 10:34 PM
25THRSS's Avatar
What fuel pressure and jets were you using?
Old Dec 25, 2004 | 12:06 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
run a 10 gauge wire to the fuel pump and wire in a 12v 30amp relay using the factory wireing to activate the relay. you should get at least 20psi out of it. make sure you use a 10 gauge wire for the ground also.
Old Dec 26, 2004 | 09:18 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
do you guys have any product recomendations for a nitrous kit?
Old Dec 27, 2004 | 02:32 PM
25THRSS's Avatar
NOS 05153 kit.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
