pics of my TT setup
Old Feb 7, 2005 | 05:27 PM
zz4z28's Avatar
pics of my TT setup
here are the pics I have so far!
Old Feb 7, 2005 | 05:38 PM
zz4z28's Avatar
my images are too big.
How do I make them smaller so I can post?
Old Feb 7, 2005 | 06:36 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Start >> Programs >> Accessories >> Paint.
Open file. Save as ____.
For reasons beyond my scope, Paint saves jpg images at a drastically reduced size (bits, not physical size). Look at my attached image. The DSC2945 jpg image is uploaded directly from my camera. I took it through the exact process I describe above and saved as 2945.jpg. Look at the filesize difference.
If the resulting pic is still too large in filesize. go back into paint and open the file:
Image pulldown >> Stretch/Skew >> pick a percentage, say 50 percent, on both the horizontal and vertical settings. Save. This should do the job.
Old Feb 7, 2005 | 08:28 PM
superirocz's Avatar
send them to me I can atleast post them on my webshots and then on here thats what i always do anyway
zperformance@adelphia.net
Old Feb 7, 2005 | 11:46 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Impressive nbrs in your sign
/N.
Old Feb 8, 2005 | 01:46 AM
BlownBird's Avatar
/N.
I'm guessing that's through a manual trans
Sick numbers either way!!!
Old Feb 8, 2005 | 07:07 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Goto this link. Sign up for a FREE account.
http://www.imageshack.us/
You can then upload full size images there. and They will actully give you the links to copy and paste for Thumbnails,full size images etc.
Great site for people who want a free image host only. and YOU can HOTLINK.
Old Feb 8, 2005 | 10:06 PM
superirocz's Avatar
the suspense is killing me
email them to me or host them on webshots or http://www.imageshack.us/
I have been waiting to see your setup for months Those are some BIG numbers for just 8 pounds of boost, turn it up
Old Feb 10, 2005 | 12:55 AM
zz4z28's Avatar
OK
here they are!'
I hope you guys like them. I am finally getting some more money to finish the little stuff now.
Attached Thumbnails pics of my TT setup-c-documents-settings-marc
Old Feb 10, 2005 | 12:58 AM
zz4z28's Avatar
from the side
Old Feb 10, 2005 | 01:00 AM
zz4z28's Avatar
from the front
Old Feb 10, 2005 | 01:02 AM
BlownBird's Avatar
Looks Sick!
Good job!!!
Old Feb 10, 2005 | 01:03 AM
zz4z28's Avatar
and from the back!
I have air filters on it now, and it's amazing how much diferent it makes the engine bay look!
I will get those pics as soon as we have a sunny day here in utah, and I am not working.
Old Feb 10, 2005 | 01:06 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
oooooooooooooooohhhhhhhhhhhhh!!! aaaaaaaaaaahhhhhhhhhhhhh!!!
IMPRESSIVE! EXCELLENT! OUTSTANDING!
Old Feb 10, 2005 | 07:13 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Sweet setup!
I have a couple of questions about it if you don't mind. First, is the hotside completely custom built or did you base it off of an existing set of headers? Also, can you describe how those downpipes are routed once they're out of site? Do they make it all the way to the back of the car??
Old Feb 10, 2005 | 07:55 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
verry sharp looking.
Deff post more info on the headers. Looks Good!!
Old Feb 10, 2005 | 08:22 AM
12secformula's Avatar
Car: 94 Z-28
*** BLESS YOU.....that is absolutely awesome. I love that. Did you do everything yourself? Beautiful!!!
Old Feb 10, 2005 | 08:27 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
did you tap your pan for the oil feed?
Old Feb 10, 2005 | 02:10 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
The oil pan itself has no oil pressure, you tap the pan for the return line so the oil has somewhere to drain back to. To get oil pressure for the feed line on a turbocharger you need to tap something with oil pressure, such as the oil pressure sending unit. I tapped the oil pressure sending unit on my mustang with a brass T, then routed that up to the top of the engine, and tapped it with another brass T that split it off to both turbos. Here's a picture for some ideas:
Old Feb 10, 2005 | 02:12 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I'll do the same. Thanks for the pics btw!!!
Old Feb 10, 2005 | 02:14 PM
Car: Junk
Old Feb 10, 2005 | 02:17 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I guess the only reason I didnt want to tap the pan would be that I didnt want it to leak. but thats cool..I'll have that done also. I'm fixing to order my sexy Dart Little M block then it goes to the machine shop along w/the rot. assy.
Old Feb 10, 2005 | 03:13 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
That is one awesome setup you have there, zz4z28!
Old Feb 10, 2005 | 07:47 PM
zz4z28's Avatar
I built everthing in my garage except the headers, I know the guy that has a program that takes all the measurements of your engine bay and then designs headers around them, he has designed quite a few sets for hendricks racing.
he designed them and then I had a friend that works for him bubild them!
the downpipes were originally going to go under the k- member with oval pipe, but then I converted to a tubular k with rack and pinion and there was no possible way to go that route anymore so they exit in front of each tire with a bullet muffler and turndowns(IT SOUNDS SICK!) with the tube k you could route them between the the pan and the k-member but it would be tight, I almost went hat route but changed my mind.
I welded a -10an bulkhead on each side of the pan for the drains.
I am running the DART little M block also, great choice!
Are you going to run a 6" rod or 5.7 '?
Old Feb 10, 2005 | 10:06 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
6" rods. I just ordered the block today.. $1699 shipped to a terminal. Tomorrow my rot. assy will be here according to UPS.. I'm very excited..and then seeing your car and how you made it work just adds to it. If you can take alot of pics of your setup I'd love to save it to my hd.. ie..wastegate install, BOV install etc.. A friend of mine is going to do all the fabrication etc...from the headers to...well..everything.
I noticed you dont have a brake booster.. what did you replace it with and how much was that?
Old Feb 11, 2005 | 06:40 AM
Car: I
Engine: Taunt
Thanks for the info zz4. Do you happen to have the name of that computer program used to design those headers? I think that would be fun to play around with a little.
And BDR, there are other options as to where you can drain the turbos, depending on where you want to position them. This is the most common tho.
Old Feb 11, 2005 | 08:09 PM
zz4z28's Avatar
the program is not for sale, he designed it himself and he only uses it at his shop.
he does allot of high end projects with it, like twin v12 offshore race boats, ultima, gt40 cars, and right now he is doing some designs for some new supercar in production with a 1000hp v12.
the company is called spectrum 5 design. do a search and you could find him on the web.
BDR- I got rid of the power booster cause the header was touching the lines and I couldn't get them far enough away, so I used the strange manual brake booster, it bolted up nicely and gave me allot of clearance on the back side of the motor.
when we have some good weather I will pull it out and take some more pics.
Old Feb 12, 2005 | 07:32 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
man...our motors are almost identical other then the heads.. I have pro-topline 235cc heads.. if you dont mind me asking..what are the specs on your cam? I'd like to order the same one..its cool if you dont want to say though.
Old Feb 12, 2005 | 07:31 PM
Rembrandt's Avatar
oh yes, that car is awesome.
That's just like how I would do mine if I had the $$$$$.
How about a low front pic looking into the grille kinda like this if the pic works:
Attached Thumbnails pics of my TT setup-c-documents-settings-administrator
Old Feb 13, 2005 | 12:44 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
This is LS1motorsports car. Its sick.
zz4z28, your car looks great.
Old Feb 13, 2005 | 12:46 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Wow-that is awesome-great HP too for such low boost. Must be pretty efficient.
Old Feb 15, 2005 | 07:08 AM
Guido's Avatar
Car: 2000 Trans Am
Wow that turned out really nice! I remember seeing pics of your headers a while back and wondering what the finished product was going to look like.
You dont dissapoint!
Old Feb 15, 2005 | 07:22 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Very nice looking. Wow... That is purty!!!
Old Feb 15, 2005 | 08:34 PM
Vader's Avatar
zz4z,
Those photos barely do justice to the craftsmanship and vision you've applied there. From what is apparent, you've done some very nice work.
Here's to hoping all goes well the rest of the way.
Incidentally, when do you expect to take it out for its first meal of continental cuisine with an oriental dessert?
Old Feb 16, 2005 | 08:19 AM
brutalform's Avatar
Gheeezzz, And I thought my engine looked good...Great attention to detail! Not to mention the "in your face" performance look!!!! If I ever decide to install turbos...Im calling you.
Old Feb 16, 2005 | 02:21 PM
TurboedTPI's Avatar
Car: 92 Formula 350
I was just woundering if the wastegates are vented into the atmosphere or do they feed back into the exhaust? Cant tell from the pics.
Old Feb 16, 2005 | 05:28 PM
83 Crossfire TA's Avatar
Huh… have you guys had any problems with tech at the track not liking the copper line as an oil feed?
Old Feb 16, 2005 | 08:13 PM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
oops, sorry. Double post...
Old Feb 16, 2005 | 08:14 PM
Yes, ditto on the cam specs please. We're cracking into the turbo car this season and I'm looking for a ballpark. Sounds like you've got it
Old Feb 17, 2005 | 12:27 AM
zz4z28's Avatar
Thank You-
thae wastegates dump into atmosphere just past the frame rails on each side.
the cam is a lunati solid roller
I.258 E.264
.600 .606
116 lsa
1.5 roller rockers
I have been extremely happy with everything i have done so far,
I had some cooling problems, but I changed my fan setup so hopefully when summer comes it will still stay cool!
originally I was going to thermal coat all my piping silver except the headers, but now I don't know?
what do you guys think?
I should get some dyno time in march with more boost and I am pretty sure we can get the low boost numbers around 800.
I will keep you guys posted!
our track opens in late april!
Old Feb 17, 2005 | 05:47 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
She's looking pretty good there Marc, almost makes me want to sell the blower and start my own TT project
Old Mar 1, 2005 | 02:00 AM
  #42
aaronl's Avatar
When are we gonna see some big HP #'s out of that badass, with some higher boost? Are you going down to the dyno day @dr. gas?
Old Mar 1, 2005 | 08:45 AM
  #43
TexasLT1's Avatar
Car: '92 RS
zz4 - just curious what pistons and compression ratio you're running. I was finding parts for a turbo engine a while back but I couldn't find any pistons for a 6" rod that were dished as much as I would have liked.
Old Mar 1, 2005 | 09:11 AM
  #44
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
How low of a CR you tryin to get? I have a 406 rot. assy w/a 6" rod + JE pistons that give me about 8.5 or so.. its 170818 in JE's catalog.
Old Mar 2, 2005 | 07:09 PM
  #45
zz4z28's Avatar
Aaron-
I am waiting for my tax returns so I can buy a boost controller and dyno time.
I doubt I will go to dr gas, I will be fresh off the dyno at phantom, but we will see!
Texaslt1-
I am running the JE dished blower\nitrous piston 4.155. it's a piston right out of their catalog, I have the oliver billet 6.0" rods
with a 3.75 stroke. The comp. ratio is supposed to be 8.2:1 with 76cc heads but my heads are 73cc with the valves I used.
Old Mar 5, 2005 | 01:18 AM
  #46
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
You have went this far i think u should definately look into getting everything coated im sure that thing puts off a lot of heat. Very nice setup!
Old Mar 7, 2005 | 10:28 AM
  #47
german-motorsport's Avatar
zz4z28...with spectrum 5 design you got some NICE friends...lol!
The Ultima is a killer and the exhaust parts pure art work!
What kind of injectors are you using?
ECU?
Headers pipe size?
can somebody in here post a website for stainless do it yourself
headers sets????
Great work the rest must be nice too? trans, axle and sus-parts
anyone guessing the 1/4 time?
Old Mar 7, 2005 | 10:30 AM
  #48
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Here's where I'm buying my turbo stuff from..
http://www.proturbokits.com/store/sc...?idCategory=32
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
TheExaminer
Sep 6, 2015 11:40 PM
