Hey guys, I thought we needed one more thread on cams!
Old Feb 21, 2005 | 11:11 AM
Formula 89 Bird's Avatar
Car: 89 Formy
Engine: 305--->TPI 350
Transmission: auto :(
Ok, I was thinking about before running boost (s/c or turbo, probably turbo) I would do the LT1 intake converison with the LT4 "hot" cam to get some decent power out of my TPI 350. I was wondering if the LT4 is worse than the stock cam for a boosted engine?
Old Feb 21, 2005 | 12:24 PM
BlownBird's Avatar
Try the TPIS zz9 cam. It is very streetable, works well with that intake and works very well with boost. I ran that cam with a 355 and Vortech and was running consistant 11.20-11.40's.
Good luck with whatever you go with>
DonB
Old Aug 30, 2005 | 01:20 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I was talking to a guy that helped design that cam. I wanted to run it with my turbo project but he was advising against it. The way he explained it to me was that the cam was more for top end then low end. With a turbo you want a cam that makes good power in low rpms.
Old Aug 30, 2005 | 11:09 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
yea with a turbo there is no need for a radical cam, stock is even fine in most cases
BRoss99
Aug 10, 2025 05:08 PM
Jorlain
Aug 24, 2022 05:11 PM
1984HO
Mar 19, 2021 11:59 AM
matthew911
Aug 12, 2015 09:38 AM
mx127
Aug 10, 2015 08:13 AM
