355 nitrous motor
Old Mar 1, 2005 | 01:21 PM
496ws6's Avatar
Car: 89 Formula
Engine: 305 is out and BBc is going in
Transmission: not sure
355 nitrous motor
has anyone built a 355 nitrous motor with nitrous cam and victor jr intake with something more than 150shot im thinking about doing that.
Old Mar 1, 2005 | 06:36 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Yes I have done a few. All of them were street cars on budgets one car ran a 225 shot using a performer rpm another a 175 shot pump gas 10.3 and a 10.8 ets
Old Mar 7, 2005 | 02:45 PM
MIKE 1985's Avatar
did you have any problems using the 225 shot on the dual plane rpm intake ? Did you have any spacers under the nitrous plate ? Also could you give more details on that motor ?
Mike
Old Mar 7, 2005 | 07:18 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
The only problem he had was trying to run the motor and nitrous off of one old holley blue pump. This was with two stages of nitrous. 125 shot first gear and a 275 shot second thru third gear. Lost fuel pressure and bent two ring glands. The car had many 225 shots and worked great. No spacers. Specs .040 block stock cast crank with eagle 5.7 rods TRW 2256 pistons block was torq plated and honed and bal. World products 200cc heads ported by me flowed 255in and 190ex comp cams 294s cam with a 106 lobe separation custom grind. performer rpm and a 650 dp carb. and 1.6 roller rockers This was also the car that went 10.3 on the 225 shot.
Old Mar 7, 2005 | 08:08 PM
EvilCartman's Avatar
Car: '82 Z28
Wish I could get mine in the 10's... maybe with some luck and tuning
Old Mar 7, 2005 | 09:59 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
evilcartman I forgot to mention im at sea level.
Old Mar 8, 2005 | 04:39 AM
Car: '82 Z28
The track I ran at was at 490 feet
Old Mar 8, 2005 | 07:50 AM
MIKE 1985's Avatar
thanks ross.
i have went 10.98 @ 124 on a 150 shot, but i'm trying to go 10.50. I just switched over to a vic jr and the car has definatly lost some bottom end, the track will tell me exactly how much. I switched because NOS said not to run more than 175 on the dual plane, but i have heard others have done it.
I don't have much motor for the vic jr. i may be putting the RPM back on. I have mine set up as a dual stage now. I plan 100 shot out of the box ( with dual plane was 1.55 60') and then 250 with the timer at 1 sec.
Mike
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Reddeath210
Oct 6, 2015 08:20 AM
JHX
Aug 29, 2015 02:30 PM
theurge
Aug 21, 2015 12:46 PM
