Supercharinging a 350 TPI
Car: 1986 Firebird
I am currently building a 350 TPI MAF and would like to purchase a charger for it as the build comes closer to an end. If anyone has any sugestions or pictures of which to use, it would be greatly appreciated.
Car: I
Engine: Taunt
Transmission: Mustangs
If you're planning on running a v-belt accessory set-up your options are greatly limited. If I am not mistaken, no one still sells a supercharger kit that will be a direct bolt on. If your running a serp. I'd say ATI is the king of the hill.
Car: Guess!
Engine: 350 Stealth Ram, Supercharged
Transmission: 700R4 / 3.73
My mechanic made my bracket where my A/C was. Works great I have a post out now called Blown or Just Blown Up. Check it out My mechanic made the bracket for my V1 S Trim, and used parts from various vehicles for tensioner/ idler, and added a crank pulley to it so the pump was seperate from other accessories. No FMU, No BTM, and No T-REX. 24lb Accel Injectors, and a Stealthram Intake with adjustable fuel rails. 58mm ThrottleBody, MSD 6AL, and a Superchip. It works very well!
