boost side or intake side???
Old Apr 11, 2005 | 07:43 PM
soon2bcharged's Avatar
Car: trans am
Engine: 350 tpi
Is it better to put the MAF on the intake side of the supercharger like i have seen in a couple of pictures in this forum or put it between the outlet of the charger and throttle body?
Old Apr 11, 2005 | 09:19 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: boost side or intake side???
Neither. Use speed density.. May I suggest running a 2-bar setup, with $58 or $60 ?
-- Joe
Old Apr 12, 2005 | 03:10 AM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
Between the blower and the TB will probaly give you a little more accurate fuel curve. On the intake side will yield a better idle, but at the cost of some accuracy.
I agree, go speed density if you can swing it.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
