need quick response
Old Apr 25, 2005 | 01:36 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
Transmission: 700R4, T56
need quick response
is this worth it do you think? is it normal that it cannot be turned by hand?
what else would i need? thanks
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Apr 25, 2005 | 02:16 PM
Guido's Avatar
Car: 2000 Trans Am
its normal to not be able to turn it by hand.
But, its a paxton. Id pass on it. Those things are junk
Old Apr 25, 2005 | 02:30 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
i really like the underhood setup, and want to be able to run stock, do any other companies make a setup like that, besides paxton?
Old Apr 25, 2005 | 07:59 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
wont fit your car anyways
Old Apr 25, 2005 | 09:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Vortech, ATI... etc (lots of good posts around here if you look)
http://www.vortechsuperchargers.com/
http://www.procharger.com/
http://tenperf.com/products/atilist.htm#3rdgenfbody
If I remember right Paxtons have a problem about redlining to quickly due to a low impeller max speed and a limited supply of different sized pullies from Paxton.
Old Apr 25, 2005 | 10:07 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
very good to know, thanks
cant swing 3k though, i'll keep looking for used, and not a paxton
Old Apr 25, 2005 | 10:18 PM
Engine: 383 SBC
Intercooling is always a plus too. Especially if you plan on using the stock motor.
Good luck on your search. Sometimes cheap kits can be found on ebay but not that often. Mostly it's either mustang, vette, or 4th gen kits. I've seen a few 3rd gens kits. One was acouple years back it was a P1-SC and intercooler went for around $1570ish + shipping.
Old Apr 25, 2005 | 10:29 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah if someone could find a blower bracket from someone that upgraded to a race or custom race bracket you could nearly complete this kit:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33741
Old Apr 25, 2005 | 10:43 PM
Engine: 383 SBC
I think you can buy that bracket from ATI also. But they'll charge you like $300+ for it.
Old Apr 25, 2005 | 10:54 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
thats more my speed
what else would i need? apologize in advance for not knowing much about supercharger management
Old Apr 25, 2005 | 11:43 PM
Engine: 383 SBC
Usually has a new inline fuel pump. Because with the FMU (Fuel Management Unit) will boost your pressure for fuel way above normal to counter all the extra air going into the motor.
From the picture looks like all the turbo style hose clamps are missing.
You'll be needing a new belt, oil, and air filter.
Also looks like he has kept the L brackets that IC mounts on.
I don't know about the tubing itself either, I would have imagined there would be more pipes.
Maybe someone else should help, since I haven't even seen a procharger in person.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
