adding Super Charger to Carbed 350
Old May 5, 2005 | 02:49 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
hey guys, i've ditched the idea of nitrous and wanna run a supercharger. it'll be going on just a carbed 350 4-bolt main. I know I will need forged pistons and rods. What will I have to do to give it enough fuel, I'm running a manual pump.
This is just a project car, so i'm open to ideas, but how much fabrication is involved in doing such a swap.
I'm wanting to go with somthing like this "Weiand 177 Pro Street Supercharger" so I don't go too big, just an extra kick in the pants. what else should I do while i'm at the upgrading. This ain't no daily driver so its alright if it gets messy, I'm wanting this car to be one of those "barely legal" cars.
Thanks fo the help if you need anymore info lmk.
Kyle
Old May 5, 2005 | 02:58 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: adding Super Charger to Carbed 350
Kyle
I would suggest a forged crankshaft as well with a blower.
Old May 5, 2005 | 03:01 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
its just putting out like 6 psi, only a 25-40%increase in power, a good cast crank can take around 650 horse up to and maybe beyond 6000RPMs.
Old May 5, 2005 | 03:49 PM
I would agree with a turbo or even nitrous, but you are tensioning the belt with the snout of the crankshaft with a blower. If you are building an engine from the ground up you might as well do it right.
Old May 5, 2005 | 08:03 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I found a good forged crank for 400, i think i'm gonna go with that over cast. How about the fuel system?
Old May 5, 2005 | 08:14 PM
x007's Avatar
Car: Supercharged Nitrous T/A
Engine: Motown 410SBC
Transmission: 4L80 - Compushift / Custom billet torq
Axle/Gears: 12b Moser 33/spl. /373 posi
take a look here :
http://www.techbull.com/transam
Kyle
Old May 5, 2005 | 08:27 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
hey man, that link didn't work for me.
BTW i heard that 6-8 psi is ok for hypertectic pistons, is this accurate?
Old May 5, 2005 | 08:28 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Old May 5, 2005 | 08:37 PM
There are a lot of people running that kind of boost with stock LT1 motors, which have hyp. pistons. You dont have a big margin for error with hyp. pistons as far as tuning goes though.
Old May 5, 2005 | 08:55 PM
x007's Avatar
they work on my side ?
Old May 5, 2005 | 11:16 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
the link worked this time. I'm not too worried about tuning, I'm pretty good at tuning on the carb, just gotta keep an eye on the A/R ratio. plus that knocks about 150 bucks off the build cost
Old May 5, 2005 | 11:22 PM
I would opt for the forged pistons to be honest. A batch of bad gas or your distributor clamp loosening up is all it would take to toast your hyps.
Old May 5, 2005 | 11:41 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
yea, sounds like a good idea.
I figure I oughta do this right, 1 set of forged pistons is cheaper than 2 sets of hypes.
Old May 6, 2005 | 02:33 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
nobody has adressed the fuel issue, I don't think a OEM replacement pump will work will it?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
