Fuel pump
Old May 19, 2005 | 10:42 PM
Treys_IROC's Avatar
Car: '89 Camaro
Engine: Blown 5.7L TPI
Fuel pump
Just a quick question:
Will i need an extra fuel pump for more pressure with my supercharger?
Supercharger: ATI procharger P1SC
Engine: 350 TPI stock
Trans: 700r4
Old May 20, 2005 | 09:29 AM
KS91Z28's Avatar
Yes, but if you're buying a new kit, ATI supplies one.
Old May 20, 2005 | 10:56 AM
Treys_IROC's Avatar
Car: '89 Camaro
I bought a used one, so do you have any suggestions on one that I could buy? or does ATI sell an aftermarket one that would be better than any of em.
Old May 23, 2005 | 12:39 AM
GreenChevelleSS's Avatar
Car: 1970 Chevelle SS 396
Engine: 414ci Big Block Chevy
Transmission: Muncie Turbo Hydromatic 400
Follow up
Will new fuel injectors be needed with the bigger fuel pump?
Old May 23, 2005 | 01:22 PM
KS91Z28's Avatar
I'm not sure what all aftermarket pumps will work, but you can buy another in-line pump from ATI for about $165.
Old May 23, 2005 | 01:24 PM
KS91Z28's Avatar
Re: Follow up
That depends on your setup. If it's a bone stock engine and you're only running 9 psi or so and the FMU, the stock injectors will be fine. The preferred way to go would be to ditch the FMU and use larger injectors along with some custom tuning.
Old May 25, 2005 | 06:10 PM
Treys_IROC's Avatar
Car: '89 Camaro
Re: Re: Follow up
Do our cars come stock with a FMU, and if i were to get bigger injectors would i not need an FMU?
Old May 26, 2005 | 09:52 AM
KS91Z28's Avatar
Our cars don't come stock with an FMU, but the ProCharger kit does. Bigger injectors and some tuning could def. eliminate the need for an FMU.
Old May 28, 2005 | 07:50 PM
Treys_IROC's Avatar
Car: '89 Camaro
So besides the things i have to do with the fuel system, is there anything else i need to prepare my car for the supercharger application, Thanks for the help,
Trey
Old May 28, 2005 | 09:06 PM
KS91Z28's Avatar
Change your fuel filter and make sure your ignition system is up to par.
Old Jun 1, 2005 | 01:22 AM
What do you mean up to par?
Old Jun 1, 2005 | 09:27 AM
KS91Z28's Avatar
I would say new cap, rotor, wires, and plugs. (Bare minimum)
Old Jun 1, 2005 | 12:20 PM
We might do that anyway, I dunno I never looked at the ignition...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
