arming switched used as NOS button?
Old May 26, 2005 | 09:30 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Is it possible to use the arming switch as a button when you want Nitrous to hit?
I will have a window switch set at about 3000 for the "ON" so if I was above the 3000 rpm with the activation button "off" could I actually flip it to "ON" and will it spray right then since I will be above the "ON" rpm setting on the window switch?
Hope that makes sense..
thanks!
Old May 26, 2005 | 09:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could do it any way you want, but you'd probably want a WOT switch in there.
Old May 26, 2005 | 09:37 PM
whoops...forgot to mention I have that also. What Im asking will work?
Old May 26, 2005 | 09:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure. If I was doing it though, I'd probably have an arming toggle switch, WOT switch, fuel pressure cutoff switch, RPM window switch, and a consent button switch just to make sure nothing ever went wrong.
Old May 26, 2005 | 09:41 PM
excellent! thanks!
edit,
I have everything that you could get with a NX wet kit, so Im set there...
whats a consent button? a kill switch?
Old May 26, 2005 | 09:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just a trigger button, but you use it more like a deadman switch. If you let go of it, it shuts it off.
Old May 26, 2005 | 10:27 PM
wouldnt taking your foot off the gas turn it off? or do you mean if a selonoid getting stuck open or something to that affect?
Old May 26, 2005 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure, but redundancy is good.
Old May 28, 2005 | 11:12 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Use a On/Off toggle swith to arm the system.
3000rpm window swith for safty.
Oil PSI and Fuel PSI units to cut it off if you loose either oil or fuel pressure.
and a Button to spray when you want. Its nice to be able to hit the button when you want instead of just at WOT.
morrow
Jan 13, 2024 12:29 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Ducati900ss
Sep 2, 2015 09:05 AM
5spdcamaro
Aug 28, 2015 02:12 AM
